Question about HP OfficeJet Office Equipment & Supplies
My hp officejet k7103 shows a blinking red light and doesnt print
It doesnt print when commanded
SOURCE: HP Deskjet D2360 Printer
i want the printer drivers HP deskjet D2360
Posted on Feb 12, 2008
  • 18 Answers
SOURCE: Printing problem in hP laserjet 1020
just inspect your printer's front cover.there r two plastic stick which is attached with the printer cover.this two stick hit the two particular point.
1.power switch conector(left side corner)
2. scanner sensor conector(right side middle)
i think your left side stick may be broke try it.
Posted on Feb 20, 2008
Khalsa007
  • 79 Answers
SOURCE: HP Officejet 5610 All-in-one printing in red instead of black!
Hi ,
As you have already tried replacing the ink cartridge , u can try to reset the printer .
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Note - you can also try the Ok n cancel key combination in place of # and 6 .in case the first combination does not work .
Thanks
Posted on Jun 04, 2008
websnail
  • 419 Answers
SOURCE: hp officejet pro k5400 will
1. Printheads have an expiry date so I'd recommend checking that the printhead has not past its expiry or something similar. It's a shot in the dark but may be relevant.
2. It's also possible that the connecting strip at the back of the printheads slot is soiled with ink or condensation... Try using a cotton bud to gently clean this strip of any moisture, wipe the contact on the printhead too (NOT the printhead nozzles!) and then reinsert the printhead.
As Rowdytown points out though, pulling the power on this printer and then reinserting after a couple of minutes usually resolves any internal issues as well by hard resetting the printers state.
Posted on Jan 24, 2009
  • 5384 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
Red button blinking on Printerhp k7103
1. remove the cartridges,
2. clean the contacts with a pencil eraser,
3. reinstall the cartridges.
4. ensure paper is loaded in tray
Apr 13, 2015 | HP Officejet K7100 Series
WHAT SHOULD I DO IF THE RED LIGHT IS STILL BLINKING I CANT PRINT IN HP OFFICEJET K7100
Here is a link to a description of blinking lights for your model HP printer at HP.com: http://bit.ly/1pMnPEu Hopefully this will help.
Aug 25, 2014 | HP Officejet K7100 Series
I want to dawnload hp officejet k7103 printer drivers
HP Officejet K7103 Drivers
Visit the above link, select the Operating System you have on your PC and download the drivers
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 15, 2011 | Office Equipment & Supplies
Two red lights below buttons are continuously blinking & printer does not printing document
Hi I mhel I have a solution for your problem, you just have to download a program called SSC SERVICE UTILITY and install it in your computer. this is a free software . Just email me if this works and solve your problem
mhel
mijamhel@yahoo.com
mhel_services@yahoo.com
May 31, 2009 | HP Office Equipment & Supplies
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Orange blinking light
hp colour laser jet 2550n while giving printing command it shows orange led blinking it dosen't print please help me.
Jul 24, 2008 | HP Color LaserJet 2550n printer + HP Color...
HP Officejet 5610 series printer problem in printing
Can you please restart your computer with your printer connected. Check for cartridge whether it has adequate ink.
try printing again and if it refuses to print just come back and advise me.
Thanks
Dec 10, 2007 | HP Compaq Presario V2000 Notebook
539 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
