Question about Fargo HDP5000 Thermal Printer
Hdp 5000 transferring error 290
Our HDP500 prints the front side but when its about print for the back page its say : ("transferring error 290"). Please what is the solution?
2 Suggested Answers
  • 669 Answers
SOURCE: my fargo printer prints black and white on the back of the card
Possible solution: Change the resin dither from Optimized for Graphics to Optimized for Photos with in the printer driver under the image color tab.
Posted on Feb 23, 2012
Fargo HDP 5000 heater error 161 fault
This error usual occurs after a large print job (50 prints in a row). Try shutting off the printer, and leaving it off for a good 15 minutes. Turn back on and retry.
If the problem persists, then you should contact a service center. It seems to have a failure in an internal sensor.
May 06, 2014 | Fargo HDP5000 Thermal Printer
Pcl xl error subsystem kernel
Try to reload print driver.
Paul
Dec 25, 2013 | HP LaserJet 5000 Printer
Error 103 headlift error fargo hdp 5000
erro 103 could cos by head voltage erro or head fit erro.
this could be a problem with the printhead lift or transfer roller headfit.
reset the printer and try again ...
Jan 05, 2013 | Fargo HDP5000 Thermal Printer
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Error code 917.00
Step Action 1 Turn off the printer and let the printer sit, powered off, for one minute. 2 Power the printer back on. 3 If the 917 error does not return on power-up, try printing a few pages. If the error does not return during printing, this may have been an isolated incident. Continue using the printer as before, but pay close attention to it for the next few days to see if the error returns. 4
If the error returns on power-up, as soon as you try to print, or re-appears at a later time, inspect the transfer roller. (Click the links in the steps below for images.)
  1. Turn the printer off.
  2. Open both the lower front cover and the upper front cover of the printer.
  3. Remove the toner cartridge and place it aside.
  4. Look at the transfer roller. Make sure nothing is stuck on the roller or wrapped around it. If you find any obstruction, try your best to remove it without damaging the transfer roller or knocking the roller loose.
  5. Make sure the transfer roller is not loose or damaged. If the roller is damaged, the roller will need to be replaced. Please contact Lexmark Technical Support or a local authorized service provider for further assistance.
  6. Spin the transfer roller. Make sure it spins freely.
  7. If the transfer roller appears to be fine, reinstall the toner cartridge and power the printer back on.
  8. Try printing again to see if the error message returns.
If the 917 error still will not clear, or if the error continues to occur intermittently, the printer will likely require service. Please contact Lexmark Technical Support or a local authorized service provider for further assistance. See Contacting Lexmark below for more information.
Jan 11, 2011 | Lexmark T642 Laser Printer
HOW DO I PRINT ON BOTH SIDES OF THE I-SENSYS LBP 5000
According to the specifications on this printer, it does not have a duplex unit for double sided printing,
The only way you can print on both sides, is to print one page at a time and then turn the page over and put the paper back in the paper to print on the other side of the page.
Mar 11, 2010 | Canon LASER SHOT LBP-5000 Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
HP laserJet 5000 Printer continually printing same page
laserjet 5000 printer A4 size printing right side line not printing .why?
Jan 14, 2009 | HP LaserJet 5000 Printer
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
Fargo HDP5000 Thermal Printer Logo
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
