Question about Bush Dishwashers
Bush wv12-75 start light flashing
Brand new still got some packaging around edges, will start and run for approx 1 min before start / pause light flashes, manual shows it as insufficient water supply, However i have take the hose off the dishwasher and is flows like a shower. Also if i stop it and restart water immeadiately flows in dishwasher....Help ???
IFIXALL
  • 868 Answers
SOURCE: fast and delicate flashing
Your control panel is bad.My advice is use your warranty if you have it .If you don't ,toss this machine out,there should have been a re-call on this .You are one of many many that are having to deal with a problem that the manufacturer should be liable for. Dont't let GE (hotpoint) go not knowing that your D/W is broken ,look for a class action law suit to be in the making,which is not enough to correct the problems at hand .I don't advise repairing this unless there is a modified part to replace the defective one. Again I'm with you on this ,and sorry for all the consumers that are ripped off by manufacturers (in my eyes) . Please rate this !
Posted on Jun 23, 2008
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
SOURCE: hotpoint aquarius FDW60 FAULT
dishwasher runs for 1 min then stops and 40c indicator and 50c indicator flash on and off together it pumps water out then stops
Posted on Oct 25, 2009
SOURCE: cda cw 496 dishwasher runs cycle till rinse light
cda cw496 stops after a few minuts then just beeps help me with my problem please
Posted on Feb 16, 2010
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
LD ERROR CODE AND WONT DRAIN LID WILL LOCK
try any button sequences yet . try holding start button and a cycle button hold both down to reset
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
Anti theft lock
disconnect the battery for 3 mins
May 04, 2010 | 1999 Ford F150 Regular Cab
I have a 6 cylinder 1996 Doge Caravan that when it heats up the engine will stall. I had the fuel pump changed and it is brand new - the check engine light is now on. I hear that it may be a sensor - any...
What engine code(s) are you getiing? Try cycling key to, on ,off, on, off, on & leave on. (not start)
now count flashes from check engine light. will be flashes, pause ,flashes for 2 digit #'s. For example: 2 flashes , pause, 2 more is code 22.
3 flashes,pause, 3 more, is code 33. Write them down & get back to us. By the way when you get 55, thats end of message.
Jul 26, 2009 | 1996 Dodge Caravan
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Printer won't print, on-off light flashes on-off
I have the same issue....two flashes of the light on the power button the repeat. The carrier is clear, so I don't know what else to do. Also, when I turn the power on, the carrier goes back and forth, hitting the sides very LOUDLY! Anyone else having this issue? This printer is a few years old, so no warranty, and of course, I just bought replacment ink for it, so now it won't work..worked fine till the ink ran out this time! PLEASE HELP!
Dec 05, 2008 | Dell Inkjet 720 Printer
Mitsubishi wd52527
does the light flash for 1 min then pause for a second then blink for another min?
Oct 18, 2008 | Mitsubishi WD52527 52" Projection HDTV
Dishwashers Logo
1,443 people viewed this question
Top Bush Dishwashers Experts
Nicola Conroy
AcmeUK
Level 1 Expert
Are you a Bush Dishwasher Expert? Answer questions, earn points and help others
