Question about Vizio SV470XVT 47 in. LCD TV
I just purchased a vizio lcd model sv470xvt1a
How do I get the pip to work I have tried everything
  • martinezlizz Jan 12, 2009
    I do have to video sources connected to the tv.
    1st on is cable connected to component #2 on the side of the T.V.
    2nd dvd connected on the back to the av #1
    can you please let me know what am I doing wrong
    Thanks
  • bahawillie Jan 27, 2009
    i have the same problem with my Vizio SV470XVT1A i have try everything please help.
Go to parental setting and switch it to No Parent Lock.
The parential unlock code = 0000 by default.
After you unlock the option for PIP becomes enabled and you can enjoy it :)
Read the user manual that came with the TV buddy , it has all that details. I had same problem hence I know
It has one of the biggest and best user guide in television market that I know have.
Posted on Feb 09, 2009
  • 362 Answers
Hi martnezlizz, I will be glad to help you with your problem,
  1. You must have 2 video sources connected to the tv.
  2. Connect your main source, cable, antenna or satillite.
  3. Connect your second source, dvd player or game console.
  4. Press the PIP button on the remote.
  5. Press the Pinput button on the remote.
  6. Choose which input you want to use as second source.
Detailed instructions can be found on page 55 of the manual and here is a link to download it. http://www.vizio.com/assets/0/92/94/118/de070116-91ba-4d18-b436-f3c168e03b53.pdf    Let me know if I can assist further and please rate this solution. lone99star
Posted on Jan 12, 2009
Vizio tv mod# SV470XVT1A has good picture but no sound. Replaced the sound board but still no sound. tried all the troubleshooting steps to no avail. What could be the reason that there is no sound?
Try the sound settings. You might have wrong format selected. Also make certain the speakers work.
Otherwise it could be a problem on the main board, or the power supply board that provides the power for the sound board.
Apr 03, 2017 | Vizio Televison & Video
Vizio SV470XVT1A model TV. Power is on, Vizio light is white, but the screen is black, no audio and no backlights present. What is the most likely problem?
Check and replace the T'Con board. It is faulty. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 20, 2017 | Vizio Televison & Video
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 10, 2017 | Vizio SV470XVT 47 in. LCD TV
47 Vizio SV470XVT1A will not turn on
Check and replace its main power regulator board as card basis.
Sep 30, 2012 | Vizio L32 32 in. LCD HDTV
I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Dec 19, 2009 | Vizio SV470XVT 47 in. LCD TV
Vizio 47" sv470xvt1a 6" wide verticle green bar on screen
Hello ,
I would suggest checking the driver circuitry for the LCD screen and I would also check the connectors from the driver board to the LCD. Either a component has begun to malfunction (hence the excessive heat) or the component has becom thermally sensitive and is reacting to existing heat and is allowwing excessive current to pass causing more heat to be generated. In any event have a qualified TV technician look at this problem because he will have the proper equipment to troubleshoot the TV in the proper fashion.
May 19, 2009 | Vizio SV470XVT 47 in. LCD TV
Tiny picture
try hitting the PIP button on the remote, sounds like it is in PIP mode, and the vizios have many configurations of PIP
Mar 19, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
Cannot get pip function to work. i try to select pip and it says not available, but in my manual it says it is available. its really weird. it is even listed on my remote, but does not work when i push it....
Some models of the TV have PIP as an option, but not installed, and to make it cheaper, they use the same remote and menus, just disable the option, as it's not supported. Best to check the Manufacturer's website to make sure that it does do PIP, not that a related model which has the same user manual does PIP.
Mar 15, 2009 | Vizio VO47L 47 in. LCD TV
Vizio SV470XVT 47 in. LCD TV Logo
1,154 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
