Question about Compaq Armada E500 Notebook
I have an compaq armadae500. I replaced the battery.The battery is no charging. How do I out what is wrong . the baterry checked out ok
Had to replace fuse inline alternator how can I transfer the inline fuse to a different wire
the cable /fuse to alternator has nothing to do with the start and run function if the battery is charged up and in good condition ,sounds like the main battery cables have a bad contact/connection or battery is shot<follow battery cables and remove all points of connection in engine bay area clean contacts with sandpaper and resecure all connections 1 AT A TIME! to make sure none are swapped around by mistake ) on both earth cable/negative and the positive/power cables,make sure terminals on battery are clean and tight , try boosting/jump starting your battery with jumper cables connected from another cars battery positive to positive .........negative to negative and see if it starts ,i doubt the problem of starting up is the alternator unless battery is flat and not being charged by alternator ,by jump starting with another baterry will give you the answer once all baterry cables and connections are clean and secure
Jan 15, 2014 | 2006 Ford Focus
Alternator wiring problem
check alternator main fuse is ok and check battery terminals clean and secured properly ,earth cable from battery to body and body to engine clean on contacts and secure ,if it still does not charge you can run a wire insulated from main connector on alternator straight to the positive of battery to rule out a break in power feed wire from alternator to the battery , is the alternator/baterry light staying on?
Jan 15, 2014 | 1998 Honda Accord
Sudden discharge of batteries
The icon may indicate the batteries are fully charged and your measurements would indicate this but I suspect the batteries are no good..
Nov 29, 2013 | Cameras
How to solve chargiong problem htc world fire a3333
test battery with a carbon pile tester to verify it is good, check all charging system electrical connections.
Jun 22, 2013 | Motorcycles
Mobile phone wont charge
make sure if your Charger is ok, make sure if your Charging pin on device is not damaged, make sure if your baterry is not totaly empty (if yes that mean it will take some time to restart charging process) if persist the problem try with another baterry to check, if with other baterry device is not charging and switching on that mean it has a Software problem, then Connect to PC suite and update firmware.
Jun 29, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Baterry wont stay charged
Recharge battery then Start the car run to normal operating temperature. Disconnect the negative battery cable, the black one, from the battery.If the car stalls replace the Alternator. If the car keeps running then the alternator is Ok.Replace the Battery.Good Luck.
Dec 16, 2010 | 1994 Chevrolet Lumina APV
I changing my car battery I put disstilled water ang I charge after 5 hours my baterry was same voltages when firts I cheked how know to if my baterry need to replace and how to know if my baterry are not...
voltage is 12 V or so, is an ok thing to measure.
But, it must be measured under load to determine if there are enough CCA or cold cranking amps to perform well in your vehicle's starting system.
Jun 24, 2010 | Car Audio & Video
The baterry dies in 10 minutes.the motorcycle has only 6700km.should i change baterry?so soon?
Yes the battery can die in as little as 12 months if it is not used often, vibration and rough roads can also shorten battery life.
Check it has water in it up to the lines.
Put a multimeter across the battery should be just over 12v with engine stopped, rise to 13-14v with engine running to check charging circuit. Riding when the battery completely dies can overload the charging circuit.
May 14, 2010 | 2008 Yamaha XT 660 Z Tenere
Why isn't my olympus camera not working and showing a red light? this has happened after I charged my camera overnight.
may be your battery is even if it charged,
try your power pack with out the battery
or an other baterry that you Know is good
if it's ok replace it.
hope that help
Feb 28, 2010 | Olympus FE-150 Digital Camera
My battery on my compaq cq50 140 us wont cut on
sir/mam you`re battery pack is need to re-pack or change the Battery pack.if you want to safe and long life Battery Pack if you use the unit inside youre house use only a charger then remove the battery pack from unit do not use both supply,like a battery with charger.if baterry full only battery,if you charge the battery charge only..
This is a only a tips For Long Life Battery Pack and Unit..Thanks
Apr 29, 2009 | Compaq Presario Notebook
Compaq Armada E500 Notebook Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
