Question about Cooler Master RS-400-PSAR-J3 400W ATX12V V2.31 Power Supply 400-Watt
Cooler Master RS-400-PSAR-J3 circuit diagram for repair
3 Suggested Answers
parinasragde
  • 526 Answers
SOURCE: I am not sure if
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Posted on Feb 10, 2011
91RSCamaro
  • 59 Answers
SOURCE: i need a repair manual
Never repaired one of these, just bought new ones if one got shorted or just happened to fail. I would reccomend putting any PC, laptop, etc on a surge protector though to prevent what seems to have occured to you on this particular unit. I lost one for the same reason and it took my mobo, hdd, and PSU at the same time. Needless to say I basically had to start over on my Asus custom build.
Posted on Sep 17, 2011
I need a repair manual for cooler master RS-550 PSU, high voltage came to our house and it got shorted
Sep 17, 2011 | Cooler Master (RS550PCARA3US) 550Watt...
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
Dear Sir, My Nokia 6300 mobile screen is undisplayable . It is good working. Pl suggest : 1 weather it is repairable 2 weather screen will be changed then what is it cost Awaiting your...
yes you can repair the screen
it will cost you as per the standard of repairing if you get it repaired from a local shop in india you may be charged in between Rs.400/- to Rs.800/- and if you get it repaired from the authorised nokia showroom it will start from Rs.800/-
Jan 13, 2011 | Nokia 6300 Cellular Phone
CAC-T05-UW .what are the brand ,model and features of the power supply compatible with it
This type of power supply is best one:
The eXtreme Power Plus RS-460-PMSP-A3 from Cooler Master pushes out 460W of power to handle your system's thirst for juice. It is compliant with the newest Intel ATX 12V v2.3 specifications so it is a great choice for both replacements and new builds.
There are plenty of connectors for all your system add-ons including 5 Molex and 3 SATA. There is also a PCIe connector for your advanced video card. The +12V output duties are divided between two 18A rails for plenty of balanced power.
hope it helps, if so do rate
Dec 01, 2010 | Cooler Master CAC-T05-UW ATX Mid-Tower...
How to check if my power supply is already not ''at the limit''?
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
Mar 22, 2010 | Cooler Master (RS-430-PMSR/P) (RS430PMSRP)...
Cooler makes noise,when it rotates.please help.
Stop beating up the tower before you damage the harddisk! If the case/PSU is out of warranty, take the PSU out and get the fan replaced. You can do it yourself, just observe the arrow direction on the fan (usually the round label should point out) and wire colors (the fan should blow out). Observe also all the precautions since the capacitors inside can hold a significant charge.
Nov 10, 2009 | Cooler Master Extreme 430 RS-430-PMSR...
I need a power supply compatible with Cooler Master CAC-T05-UW. Features are ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 External 5.25'' drive bays, 2 External 3.5'' drive bay, 2 Internal...
The Cooler Master RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified Crossfire ready 80 PLUS certified modular active PFC.
Cooler Master eXtreme power RS550-PCARE3-US 550W ATX12V V2.3 SLI ready CrossFire ready power supply.
Two models that should fit with that tower. Cheers!
Aug 19, 2009 | Computers & Internet
The camera CCD-TRV228E goes to camera mode ON without putting the switch to on position when the battery is connected Please give a circuit diagram or a service manual as the Service Center is blackmailing...
Here is a link website (sony U. S. said it was a Europe product.I am in the U.S.)
http://support.sony-europe.com/dime/camcorders/v8c/v8c.aspx?site=odw_en_US&m=CCD-TRV228E
Link to PDF manual for CCD-TRV228E
http://pdf.crse.com/manuals/3087919141.pdf
This website says they have a copy PDF service manual for CCD-TRV228E at $15.99
http://www.servicemanuals.net
Here is the link below or copy paste
http://www.servicemanuals.net/ServiceManual/SONY/CCD+TRV228E/pos1/results.aspx
I typed in TRV- 460E , but I was not sure it was a correct match you might want to double check.
I couldn't find any circuit diagrams at this time.
Hope this helps you
Nov 07, 2007 | Sony CCD-TRV228E Camcorder
Replaced mother board now damper clocsed
rip, couple of checks to do: On the main board, connector J3. On the harness you should have 400 ohms on J3-1 (yellow) to J3-2 (red/black) and 400 ohms on J3-3 (white/brown) to J3-4 (blue yellow. Same values should be at the damper motor. If you don't have those values, damper motor defective. One other check, you have 10 seconds to do this on power up, so get some help. Plug in the refer. Check for 6 VDC. DC voltage now from pins J3-1 to J3-4. If you don't have this it's the board. If you do have this and the dampers not working, replace the damper. Catriver.
Aug 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Cooler Master RS-400-PSAR-J3 400W ATX12V V2.31 Power Supply 400-Watt Logo
76 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Avishek Samaddar
Avishek Samaddar
Chris Larocque
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
