Question about Fisher and Paykel Refrigerators
Fisher & paykel fridge manual
E522BRXFDU3
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: Error code F32 for fisher
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Why does my fisher and paykel active smart fridge/freezer keeps beeping when I open fridge? As if the fridge has been open for a long time?
Does the beeping start immediately or does it follow the designed timing as stated on page 12 of the manual? You would have to check with the manufacturer to see if the feature can be disabled. Page 12 of Fisher Paykel Refrigeration User Guide ManualsOnline com
Mar 08, 2015 | Fisher and Paykel Refrigerators
How do I disconnect the plumbed water to my Fisher & Paykel fridge?
Shut the water down and disconnect water line behind your fridge and remove your fridge
Jan 11, 2015 | Fisher and Paykel Refrigerators
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
