Question about Compaq Presario Notebook
Sound/audio is out when i use my laptop after minutes of using it
Sound or audio for my laptop is out when i didn't use or didn't listen to any music for about 5 minutes of using my laptop. but when i restart my computer, the audio is okay again.. is there any settings in this computer that i need to change so that i could listen to anything even if i never used audio when i opened my computer? HELP! i purchased Compaq presario CQ40-109TU..
Tip
To connect a music player or other audio device to your laptop
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
on Dec 14, 2010 | Computers & Internet
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
Don't listening to me any sound from my pc. Before i set up windows xp sp2 to my computer. then i can listening any sound from my pc. Today i set up windows 7 to my pc. After that i can't listening any...
Hi There,
You need to update the sound drivers on your laptop, because the sound drivers on your computer is for XP and the drivers that you must be having should be for xp. So download and install the latest version of audio drivers for your computer.
Please follow the below link and download the sound drivers respective to your laptop,
http://notebook-drivers-download.com/
Note : If your computer manufacturer's name is not listed in this website, then you might have to visit the manufacture's official website to download the latest audio drivers for your computer.
Enjoy installing the sound drivers and enjoy listening to some good music. !!!!
Oct 23, 2010 | Computers & Internet
My sound is only in analog in my Dell Studio Laptop. I have tried everything the computer suggests but can not get a stereo sound from it.
Hallo!
my laptop is an HPdv2700 i recently installed an XP operating system after previous using vista and suddenly my Audio device on high definition Audio bus is missing. so, I cant play video or listen to music... can u please help me solve this problem!
Jul 08, 2009 | Dell - 0089D Sound Card
I cant hear the sound when i play movie or music
The issue could be with audio settings of your laptop or with the sound application that you are using to play the audio such as Windows Media Player.
Check if you are able to listen to audio in another application such as Real Player.
I recommend you to try the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/no-audio-in-notebook.html
Jun 24, 2009 | Computers & Internet
Toshiba laptop sound
If you are using media player to listen to your audio files then go to 'view' 'show enhancements' and make sure the graphic equaliser is set how you want it, while here click on 'default' and lots of options will come up on how you want to listen to your music.
hope this helps
Nov 02, 2008 | Toshiba Satellite A75-S206 Notebook
Toshiba Satellite Pro A200 - Vista - Sound problems
You should check if in the device manager the sound card shows up. Also, check the BIOS to see if it is not disabled.
Oct 27, 2008 | Computers & Internet
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Hope this helps!
Jan 22, 2008 | Creative Labs Sound Blaster Audigy LS...
Compaq Presario Notebook Logo
81 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
