Question about HP DesignJet 1050c InkJet Printer
Driver to HP1050C ...
I need to build a plotter file to HP1050C through AutoCad 2007, (which is longer than 1999 mm - so I have to customize paper size.
In order to do so - the program has to recognize this plotter's driver.
please help me to find the wright driver to install into the programe.
(The plotter itself is NOT in my possession.)
  • Anonymous Mar 27, 2009
    error system
  • 24 Answers
Friend,
All drivers for the 1050-series printers can be found HERE:
Hope you sort it out.
If not, could another solution be to save the file as a .pdf and send it to your customer?
//Al
Posted on Mar 08, 2009
HP1050c plotter low memory - file size increases when sent to plotter, from 150 kb to 16.5 mb
Up grade memory to over come from this issue.64 MB Memory..P/No:C6251A32 MB Memory..P/No:C6252AHow to replace the memory?: Browse the link:http://www.youtube.com/watch?v=Lxr7HSIWTXI
Dec 06, 2011 | HP DesignJet 1050c plus InkJet Printer
Print jobs print as portrait and not landscape
you need to change the print settings in the program where you are printing, when you go to print settings the option should be in the dialog box where you choose the printer and page amount.
Mar 02, 2011 | HP Designjet Z6100 InkJet Printer
Hi, Our HP1050c doesn't cut the paper after print à draw made with Autocad2011. Any idea ? Install and reinstall the drivers change nothing. We use XP Pro x64. Thanks for help.
It is probably the belt is going bad or the slider rods are dirty. Turn off the cutter and see if everything works ok, which I suspect it will. Check for small bits of rubber inside the plotter where the belt runs. If you see pieces, it is the belt that is fraying. Clean and lubricate the slider rods should also be done.
Please find below your Service and repair manual, use this to troubleshoot your issue.
http://printer1.blogspot.com/2007/11/service-manual-designjet-hp-1050c.html
Aug 17, 2010 | Office Equipment & Supplies
Our 450C plotter is connected via E-Net Hub and has extened memory. The "Test Printer" works. However it will not complete an Auto Cad Drawing. The ready light continues to flash but the plotter stops. any...
This could be one of a number of things. The file being sent must be smaller than the total memory of the printer. Connect the computer directly to the plotter with a parallel printer cable and see if it prints. If you are using an OS newer than XP, try using the XP 32 bit driver. If you are printing from AutoCad 14 or older, upgrade AutoCad (newer uses Windows printer drivers). If you can print OK with the parallel cable, get new external JetDirect software from the HP website.
Jan 15, 2010 | HP DesignJet 450c InkJet Printer
HP 110 plus shows problem with black printer head
Glad you mentioned Autocad has a printer/plotter setup setup
Jul 28, 2009 | HP DesignJet 110 Plus InkJet Printer
When i'm going to print an autocad 2009 document to the hp 500 printer with jis b0 format and biger the spooler of the printer crashes and doesnt print
If you are using Windows Vista OS, then you know that you do not have the complete drivers that should make all the features of the plotter work ok. It is recommended that you go for XP or 2000. That way, better results including fonts are achieved. Remember also that this model is old and may not really work very well with all the features in Autocad 2009 Version. You can try the plotter on a machine running on 2007 version. Good luck
Apr 29, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
Problem printing with Deskjet 1280
pls install plotter dirver for autocad .
bye
Dec 01, 2007 | HP DeskJet 1280 InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
854 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
