Question about Denon TU-260LII Tuner
ANTENNA ON TU380RD
I do not get any proper station am / fm on my Denon TU380 RD The sound is extremely low, almost inaudible
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Posted on Sep 16, 2006
  • 85 Answers
SOURCE: Denon DRA-555 Memory won't hold set FM stations when powering up
Most probably the memory capacitor / battery inside soldered to pcb
Posted on Jan 09, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: FM antenna is not providing
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Posted on Sep 14, 2011
My str de 925 will no lock on a radio station
Insure that the antenna is connected securely on their respective antenna
input, Stations will not lock , if the signal is low.
For FM :
• Wire antenna is applicable if your distance to the nearest FM
is about a km or less, other wise use a VHF TV antenna.
for AM :
• These antenna is directional, you may need to extend the wires
so as to receive AM stations.
Jul 31, 2012 | Sony STR-DE925
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
Sep 14, 2011 | Denon DRA-37
I can receive FM stations properly. I cannot receive AM stations at all. Only a static sound. I disconnected the AM antenna leads and used an Ohm Meter. The meter read full continuity when I touched...
you may be in an area where am stations don't come in,, am uses straight lines of frequency where FM uses a modulated signal, which travels much farther, I bought a antenna signal booster from radio shack for a few dollars , and was able to get the stations, some pretty static filled though, but the more local ones came in ok, another thing to check is that the unit is plugged into a grounded receptacle ,
Sep 10, 2011 | RCA RTD217 Theater System
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
1998 Wrangler Sahara - radio not recieving low freq FM Bands
if you are receiving stations on the higher frequencies then your radio is the problem and not your antenna or anything else
Jan 13, 2009 | 1998 Jeep Wrangler
Denon Receiver AVR-1600
Seeing as you can't put an aerial outside, can you put one in the loft space, if you have one. You could use a standard FM aerial. It wouldn't be as good as mounting it outside, but it would give you better results then a wire.
Jun 20, 2017 | Denon AVR-1600 Receiver
Tuner Woes
check your antenna connection in rear and try different location for your antenna----outdoor antenna is better.
May 24, 2008 | Denon AVR-1803 Receiver
Radio stations have shushing sound
Cheap table top radio is mono. Your Denon is not getting a good signal so you are hearing noise. You need a better antenna (roof type) or the antenna needs to be moved and aimed in another direction. Try moving it while the station is tuned. You can also switch the Denon to mono and it will reduce the noise at the loss of fidelity.
Sep 02, 2007 | Denon AVR-587
No radio
Sep 16, 2006 | Denon AVR-1100 Receiver
Denon TU-260LII Tuner Logo
42 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
