Is Matsui VN9720 VCR compatible with Digital TV?
I am using Scart cables.
The Wolf
  • 10 Answers
SOURCE: black & white picture on vcr & dvd playback
Check your VCR or DVD for correct region and standard. If I had a camcorder, VCR, or DVD player here in America on Pal standard or eupopean region the same thing would happen.In fact I accedently did that on an unknown switch on the camcorder.
Posted on Dec 05, 2007
SOURCE: VCR will not record (PV-V4624S)
SET YOUR TO RF LEVEL " LOW" OR YOUR CABLE CONNECTION IS WRONG CHECK IT.IF THE PROBLEM REMAINS, CHECK IT ON STANDARD DEFINITION TV FOR RECORDING.IF THE PROGRAM RECORDS OK THEN IT ID NOT COMPITIBLE FOR DIGITAL SIGNALS. BUT IF NO RECORDINGS PERFORM CHECK THE VIDEO HEAD CLOGGINGS OR MAY BE MAIN "IC" PROBLEM.
Posted on Feb 23, 2009
SOURCE: Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Posted on Jun 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: Matsui VP 9501 0P VCR - Digital TV ready?
The converter boxes can hook right up to any vcr on the antennae in jack. They work just the same. I like using vcrs because you can hook up anything to them and then run it to tv. It's great!
Posted on Nov 17, 2009
Grubhead
  • 5487 Answers
SOURCE: VCR playback to TV
Has the TV got more than one scart socket? If so try a different one, as some are not designed for VCR playback. Also the scart lead must be fully wired, check that it's not damaged (look at the pins carefully). Scart leads are good at causing all sorts of trouble, so make certain you have a good quality new one connected.
Posted on Feb 19, 2010
Connecting VCR ,cable box, TV
First connect the cable box to TV using HD-cable (if connection available) or component cable (three leads) observing the colors. Connect cable box to VCR with an S-video cable or SCART if you have an S-video out scart. Connect VCR to TV with another S-video cable (round connectors) or with a scart to an S-video in scart connection. If you are in the US, the scart connections don't apply.
Sep 30, 2013 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Nov 17, 2009 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
Hi i need drivers for my matsui vcr so i can link it to my pc .the model is VP 9407A
You cannot get a driver for a VCR, to link it to your PC you need to have either a TV card or a video capture card fitted to your PC then you can link the a cable from the VCR to this card either by using a component or composite cable or Scart to composite/ component cable depending of what type of input your card has, then the software driver for the capture card would be insatalled onto your PC. This enables you to play video through your PC either to watch or convert onto a disc etc.
Aug 27, 2009 | Televison & Video
Jun 17, 2009 | Hitachi Televison & Video
How to connect two vcr via scart cable over old tv
what you mean old tv ? with not scart conection?if yes,conect first vrc to second vcr via scart and second vcr via rf cable to tv if no scart socet on tv or via scart if tv have scart conection.
Aug 14, 2008 | Televison & Video
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Oct 06, 2007 | Televison & Video
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
