Question about Gaggia Brera Coffee Maker
How to descale gaggia brava bean to cup machine
How to descale
SOURCE: descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Posted on Aug 17, 2008
LaPavoniBoy
  • 36 Answers
SOURCE: coffee takes 10 minutes to fill cup and very noisy - Classic
The most common problem with these machines is scale. Using a good descaler to start with may help but may not always solve the problem. If your machine is noisy it is the pump which may need replacing. If you open the steam valve when making the coffee it will shift any air lock. Out with that you may have to remove the shower plate underneath where the coffee handle goes and give it a good clean. Also there is a safety valve inside the group head which may be clogged up. I am a domestic coffee machine engineer based in glasgow and have machines sent to me from all over the UK. It is hard to eally fix problems without actually seeing the machine as it could really be anything. Boilers are small so tend to fill with scale and ****. go to www.theespressoshop.co.uk if you require any more assistance.
Kind Regards
David
Domestic Coffee Service
Posted on May 28, 2009
EsWorld
  • 1618 Answers
SOURCE: will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Posted on Feb 05, 2010
EsWorld
  • 1618 Answers
SOURCE: I have a GAGGIA SYNCRONY DIGITAL COFFEE MACHINE,
The grind is set too fine adjust to a coarser grind.
Posted on Mar 02, 2010
EsWorld
  • 1618 Answers
SOURCE: I have a gaggia platiniun bean to cup. i am using
The grind might be too fine, and so the machine extract the coffee, try making the grind a little coarser.
Posted on May 30, 2010
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
Why after descaling my new Seaco Syntia coffee machine, it stops while brewing and it requires being primed over and over.
Syntia and Brera machines are made by Saeco. Brera is marketed under the brand name Gaggia (owned by Saeco).
The causes for this malfunction can be due to following in order as stated:
1- The machine was not descaled or it was descaled using products. that are labeled as descaler but they are not. After extended period of not descaling, one may have to use more than one cycle of descaling to remove accumulated depsits of Calcium in the water system.
2- The grind setting of coffee is too fine. Make it coarser by one notch toward coarser setting at a time.
3- The pump is losing its pumping pressure and not pudhing water through the coffee. Replace ULKA pump with an Invensys pump model CP3.
All fully automatic machines are convenient and make classic shots of espresso from bean to the cup at the push of a button. With this simplicity, owners forget its maintenance until machine stops working. Please pay attention to descaling every three months. No excuse is good enough.
Services Unlimited Inc Parts Guru
Oct 18, 2014 | Coffee Makers & Espresso Machines
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
Descale alarm wo'nt turn off after a full descale.
You have to reset this manually after descaling. This is done by pressing the bean selector button for 6 seconds.
Nov 10, 2013 | Gaggia Brera Coffee Maker
I have a gaggia platiniun bean to cup. i am using ground coffee at the moment but it keeps coming up brewing failed Why?
May 30, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Will grind the coffee beans but no water passing
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Gaggia titanium coffee beans empty
Hi
If the big knob in the bean hopper is on a small #, that could be your problem. try opening the knob to the largest # and try again. If it clears and makes a cup, then on the next cup, while the grinder is operating turn the knob down again, but to a larger # than you had before. Grounds can get compacted in the chamber and prevent new grounds from entering. That is why it grinds but doesn't make a coffee. If that doesn't help, try opening the door above the brew unit funnel when the brew units is out. It should pull down on a hinge. This is the clicking you hear when you make a coffee.
Oct 20, 2009 | Gaggia Titanium Espresso Machine
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
Gaggia titanium dispenses different amounts of brew
First thing to you should try is descaling your machine if you haven't already. If descaling does not work then it might be some kind of leak issue.
You see, when leaks are present internally in the espresso machine it varies the amount of the cup, because a portion of the water which should have gone into your cup, has leaked into the machine.
It looks like your machine needs some service.
Visit www.CeriniCoffee.com if you need service in the New York City Area.
Jun 19, 2008 | Gaggia Titanium Espresso Machine
Gaggia Brera Coffee Maker Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
