Question about Dryers
My LG dlg1320w gas dryer will not heat. - Dryers
    Top Expert:
  • Dryers Master
  • 14,161 Answers
Posted on Feb 22, 2016
megarza
  • 88 Answers
SOURCE: gas LG dryer wont HEAT
hopefully this manual has what you are looking forhttp://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Sep 21, 2009
  • 291 Answers
SOURCE: Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Posted on Oct 14, 2009
Testimonial: "Thanks very much, I read about Liquid Propane and Propane vapor and kinda felt silly asking the question, but didn't want to take a chance."
  • 105 Answers
SOURCE: My lg dlg7188rm gas dryer will not heat. the gas
Sounds like you need an ignitor part number 5318EL3001A but you will need a gas technician to work on this legally. Best off to call a reliable service company such as Sears.
Posted on Feb 01, 2010
Testimonial: "great explanation. thanks,"
  • 572 Answers
SOURCE: LG DLG0452 Gas Dryer. Starts and heats fine. Shuts down early.
check for proper venting
Posted on Feb 06, 2010
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Posted on Jul 04, 2010
LG dlg1320w dryer bottom lights up, is this normal?
see the diagram attached:
6_15_2012_12_48_33_pm.jpgthe light is on when you open the door switch, see the diagram, if doesnot light is indicative the switch is defective or open or thermal fuse is blown. God bless you
Jun 14, 2012 | Dryers
Where is the reset on a LG dryer model #DLG1320w
There is no "reset" on the unit. What is the problem you are having?
Apr 17, 2012 | LG DLE0332 Gas Dryer
My lg dlg3744 gas dryer will only occasionally heat any ideas?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 14, 2011 | LG DLG7188 Gas Dryer
LG Gas Dryer not heating up
heatman101
Mar 24, 2011 | LG DLG5932W Gas Dryer
Tromm LG gas dryer 5988 gas wont turn on says DRYING but it's not Everything else works
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | LG DLG5988 Gas Dryer
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
Lg dryer wont heat up DLEX7177RM how do I reset the thermostat
heatman101
Apr 30, 2010 | LG DLG3788W Gas Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
I have new DLG1320w gas dyer and do i have to buy the sepcial gas flex for it
Hello rubendidit,
Many home improvemnt stores such as home depot and lowes carry flex gas lines and shutoffs for these applications.. Some states require the gas line to be hard plumbed in so check applicable laws and use your own judgement. If you decide to go flex ( they are usually yellow colored) you may also consider picking up some 'snoop' leak checker ( sudsy water based product you daub onto fittings to make sure you don't have any gas leaks.. You put it on fittings and watch for bubbles.. if you get bubbles.. shut off the gas and repair the fitting with proper thread sealant.. Good Luck
Regards,
Rick
Dec 04, 2008 | LG Dryers
Dryers Logo
79 people viewed this question
Top Dryers Experts
