Question about Microsoft Xbox 360 Console
Xbox 360 error code e73
When i turn on my console there is one red ligth an it reads on my tv screen error code e73 is there a way to fix it?
  • 6 more comments
  • umozilla Jan 12, 2009
    It's the same thing. 4th light and error code E 73.
  • 08_lewis Jan 14, 2009
    when i turn on my xbox it says error code e73
  • Anonymous Jan 15, 2009
    what do i do?
  • Anonymous Jan 16, 2009
    My xbox froze up and there was a message saying E 73
  • Anonymous Jan 25, 2009
    it comes up e73 when i turn it on
  • staffie mad Jan 28, 2009
    i have had my xbox for 6 months and now its showing 1 red light with error E73 i have seen that this is the worst error to get my warranty says 15/05/08 to 09 so im not sure if i still have till the 15/05/09 to use it? does any one have any tips for me/ i haqve already disconnected everythingf and checked all the cables
  • Anonymous Feb 08, 2009
    I have the same problem, but the ethernet port is not the problem. When i take it out turn the Xbox on the error is still there.
  • Anonymous Apr 01, 2009
    i turn it on nd simply it says error in mny different language when i berly turn it on
Two days ago i was playing my xbox like normal got off got back on 3 hours later and i got one ring in the lower right quadrant (if your xbox is on its side) and got error e73 i noticed that the light went away when i removed my a/v cable the light goes away can someone please explain and dont say its a problem with the ethernet port im tired of hearing that
Posted on Aug 12, 2009
The Internet Port or Referred as the CPU or GPU is fried and needs to be turned in the Microsoft for repair. No other way that i Know will fix it.
Posted on Jan 19, 2009
I just tried the towel trick...I have the e 73 problem also...It worked for me....atleast for 12hr.....I'am doing it again for the second time...I know its not a long term fix but f*** it I just want a little more time with my baby.
Posted on Jul 30, 2009
Go Onto Youtube For Fix
Posted on Feb 27, 2010
    Sergeant:
    Champion:
  • 378 Answers
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
Posted on Jan 12, 2009
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
I turned on my xbox 2 find 1 red light comes on and the screen says system error e73 code.any help wud b appreciated.
ok there is a problem with your ethernet port you can call microsoft at 1-800-4my-xbox try blowing the dust that can block the port and hope it fixes the problem or look at a guide to fix the error code your self
Nov 30, 2010 | Microsoft Xbox 360 Elite Console - Black
Have a partial red ring. in the 4th controller position, with a E 73 code on the screen. how do i fix it?
3 ways to fix the Xbox 360 E73 error
1. Restart your console.
2. Unplug all AV cables, and also unplug the power cord from the wall socket. Once that's done, plug them all back in correctly, and put your console back on.
3. Take out the hard drive, and put your console on. If the troubleshooting error has been gone, put your console off, and get the hard drive in again. Than put your console back on.
If these tips didn't fix your Xbox 360 E73 error, you will have to open up your console, and fix the problem from within. You can do this by 2 ways. You either send it over to Microsoft, or you will actually repair the troubleshooter by yourself with a repair guide.
hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: one red light code E73 appears on screen...
your xbox is going to die..
but there is a way that you can play it.just heat up your xbox for couple of mins.then try again.it works.
every time you see E73 error just do this
for more help email me how to do.
azibajwa@yahoo.com
May 17, 2010 | Microsoft Xbox 360 Console
One red light and a e73 error code??
Hello sir
May 15, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Apr 14, 2010 | Microsoft Xbox 360 Console
E73
http://www.xbox-360-red-lights.com/solving-xbox-e73-error
Got the Xbox 360 E73 error? Want to get it fixed? Fact is that this problem may be tough to fix, and that's why many people will tell you to send your console over to Microsoft and pay $150. But is it really worth your $150? Is there maybe another way to get it fixed? The Xbox 360 E73 error may be tough to fix, but this doesn't mean that you can't repair it by yourself.
Fix Xbox 360 E73 error by Microsoft or by myself?
So what to choose? Well, if you send your console over to Microsoft, you will have to pay $150 if your warranty has been expired. Also, you will have to wait for 2-6 weeks before you can get back to playing. You'd better want to avoid this... Right?
It can be done way faster and cheaper... If you fix the Xbox 360 E73 problem by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, visit: Xbox 360 Repairs
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix E73 Error
Apr 13, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
E73 error code comes up 1 red light
From a little research I have read from other posts that the e73 error is a hardware issue. Problem may be caused by a problem with the ethernet port or supporting control devices. If you system is still under warranty, I would have xbox fix it first. If you open it up and break the seals then your warranty will be compromised.
Aug 02, 2009 | Microsoft Xbox 360 Console
Sysem error E73 on Xbox 360
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
Mar 31, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
5,036 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
