Question about Toshiba Pa3974u-1c0k Camileo X400 Camcorder
Why is there a black screen on Toshiba camilio x400
Brand new camera, battery charged per instructions, view screen stays black and won't come on. Camera appears to turn on, light on front turns on, blue light comes on fine. SD card inserted or not makes no difference. What's wrong with it?
  • 6 Answers
SOURCE: Toshiba Satellite A135 Battery Issues!!!
Here's what happened (The fix is at the end):
8 months after buying my Toshiba A135 the battery began charging only intermittently. It also would not run without the battery. I put up with it for a month then took it back to Best Buy to get it repaired under warranty. They kept it over 2 weeks then gave it back saying it was the battery, which they replaced. One week later I had the same problem again. Back to Best Buy. The guy at the counter said it was probably the battery, they had encountered a lot of that. I said no, explained it, and gave it over to be fixed. 2 weeks later I got it back. They had reset the BIOS, no hardware replacement. I got it home and it was not fixed. I took it back the next day. They kept it 2 more weeks. They replaced the motherboard. I took it home and...you guessed it the same problem on the day I got it home!!! I took it back with one week left on my warranty. I don't remember what they replaced the last time but I think it was the motherboard again. I got it home (2 weeks later) and THE SAME PROBLEM on the day I got it home. So, the lesson there is that Best Buy computer maintenance SUCKS!!
I called Toshiba to try to get them to fix it for free, and out of warranty. After several frustrating minutes of conversation with an accented person who just kept telling me that my warranty was up, I hung up and called back and got an English speaking person. SHE was very helpful, listened to my problem, agreed to give me a one-time fix ticket. They paid for the postage. When I got my computer back it was mostly fixed.
The problem was the module at the back of the computer where the power cord plugs in. It was defective. Some wire or solder had gotten loose. They replaced it and it worked fine after that, except that when it goes into sleep mode it will not wake up. I fixed that by turning off all the sleep mode options. BTW, a friend of mine with the same computer is now having the same problem.
Posted on Oct 22, 2008
  • 17 Answers
SOURCE: screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Posted on Feb 22, 2009
kbdesign
  • 370 Answers
SOURCE: There is a black screen that comes up asking for a password
Somebody got into the bios and entered either a hard drive or a bios password. You will have to know which one it is.
Posted on Mar 16, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Posted on Apr 22, 2009
  • 8457 Answers
SOURCE: toshiba 32av502r lcd tv keeps
The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Nov 21, 2010
I have a GE X400 When I turn it on the lens extends out and stays in that position. It will not shut down either and the screen is black.
I also encountered the same problem on my camera. I pulled the batteries out and put them back in. I haven't had it happen again.
Apr 18, 2013 | GE X400-BK 14 Megapixels Digital Camera -...
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Battery won't stay charged, it is brand new battery, alternator has been checked and it is good, blown BTN 60 watt fuse, on 1994 Mazda Protege.
The 60amp fuse probably is in the circuit between the alternator and the battery. Which would be why the battery is not getting charged.
Someone would need to check for a short in the wiring between the alternator and the battery.
Oct 15, 2012 | 1994 Mazda Protege
Downloading photos from GE X400 to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 20, 2012 | GE Power Pro X400-WH White 14.1MP 15x...
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jan 16, 2012 | Kodak EasyShare Z740 Digital Camera
When turned on camera beeps 3 times & the zoom
Does it take standard disposable batteries or a rechargeable pack?
If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries.
If the second type, recharge the pack.
If problem continues check Troubleshooting section of manual or online at Samsung's website.
Sep 20, 2011 | Samsung Digimax S600 / Kenox S600 / Cyber...
My camera won't turn on...it is brand new
Brand new as in you just opened it out of the box? If thats the case you have to charge the re-chargeable battery first, then put it in the camera and it should work fine. Try giving the battery a charge first if you haven't already.
May 21, 2011 | Polaroid i1237 Digital Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Toshiba Pa3974u-1c0k Camileo X400 Camcorder Logo
Top Toshiba Cameras Experts
john milligan
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
