Question about Panasonic PT-52DL52 52" Rear Projection Television
Tv cycles on and off
When tv is turned on, the green bliking light starts, tv comes on(green light now steady as normal). after about 10-15 seconds, tv shuts off, but green light starts blinking again and tv will come back on, then cycle just keeps repeating itself.
  • john williams Jun 24, 2007
    fix was new lamp, not what tech said
    President:
  • 3,130 Answers
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Posted on Jun 09, 2007
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
It shutts off ramdomly the red lite blikes an have to what for green light to come on before it turns back on
Tv "LAMP" LED lite indication flashes or staying on?The tv projection lamp life is over.The projection lamp require changing.
Aug 06, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Television turns on and off
Almost certainly the lamp.
Apr 09, 2009 | Televison & Video
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Tv problem
hold the menu button down for 10 seconds tv should power up you will have to turn off front panel buttons on menu hope this helps
john
Jan 24, 2008 | Mitsubishi WS-65615 65" TV
Panasonic PT-52DL52 52" Rear Projection Television Logo
287 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
