Question about HP Laserjet Pro 400 Mfp M425dn Multifunction Laser Printer
Error code 49.0138
HI, Can any one advise as to what this Error code points to for the M425dn HP Printer (49.0138), the service manuals arent any help
Nikhil Gedam
  • 87 Answers
SOURCE: HP LJ4250dtn 49.5F11 Service Error
49.xxxx error occurs when the printer does not understand the Print Job Language. Following could be the reason:
  • Faulty Network Cable/Port
  • Corrupt Driver
  • Firmware of the printer and the Jetdirect Interface.
  • Corrupt file.
  • Corrupt Print job.
  • Less memory or corrupt memory DIMM
Hence to start with, please let me know when do you get the error. Is it when you powercycle the printer.
Please perform the following:
  • Upgrade the firmware of the printer and the jetdirect card.
  • Change the driver and install the UPD drivers.
Let me know the next update...
- Nikhil
Posted on Nov 05, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
Posted on Mar 05, 2009
  • 96 Answers
SOURCE: HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Posted on Sep 28, 2009
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
Hp leserjet pro 400 mfp scaner error 52
The scanner initialization did not pass it seems. Try cleaning the glass and white background.
If that doesn't work, the scanner bulb may be faulty - try replacing it.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
Hp leserjet pro 400 scner error 52
The printing scanner (laser) has likely failed. HP has had some issues with the series of products and bad laser scanners so you may want to contact their customer service to see if you can get it fixed under warranty.
How to fix the error?
you might have to repair or reinstall the program
HP LaserJet M425dn MFP 79 Service Error
How To Troubleshoot HP 79 Error?
This is a fairly found as a common HP printers error which is usually caused by malformed PostScript documents in the HP printer. According to the study by a HP error 79 technical support professional team experts, printer shows a "79 Service Error" on the LCD display. HP service error 79 is a considered as a quite generic issue which is found on the HP LaserJet printer while working. Most of us face this same issue unexpectedly. But there are ways to get over with it:
What you need to have?
- Internet access.
-Admin account for the computers
Steps to resolve this HP error code 79
    ?In the very first step, you are needed to switch on the LaserJet Pro 400 printer.
    ?Ensure that the printer is properly connected to the internet. Users should be able to have a strong
    ?Ethernet cable connection running from the device to their modem or may even require to switch or a router.
    ?Now in the M401dn control panel/display section, click on the "Network" icon first.
    ?As per as study by HP error 79 tech support is concerned by a HP error 79 tech support technicians, verification of the IP address on the printer machine is necessary. Well, if it shows 192.168., then it clearly signifies that you are well connected to your home network. Else, a small check is needed to receive a symbol like 169.....
    ?Now step back to the home display section and then click on the "Settings" icon.
    ?Choose an updated LaserJet printer and then perform a check for all the firmware updates to ensure about all the latest updates.
    ?Continue the process by choosing a proper update and then click on the download and install button
    Fix your HP issues anytime with our HP professionals
    We deliver the best-in-class HP customer support service solutions for HP users across the world equipped with top-notch HP printer support solutions by applying the latest technologies to match users' need. Our HP printer support Toll-free 1-800-213-8289 number is all-time accessible for users across the world at our toll-free calling contact details to fix various critical types of HP printer problems affecting the performance of your HP printer. Prices are extremely feasible in nature.
Sep 16, 2013 | HP LaserJet Pro 400 MFP M425dn
Error code 13.20.00 for hp laserjet m 4345 mfp
Hi!
According to HP service manuals, the error you described is in the category:
JAM INSIDE TOP COVER AREA
and more specific:
The pre-feed sensor, the top-of-page sensor, or the fuser-delivery
Those are the points where some paper pieces or even dust can be stuck.
Hope it helped,
Bogdan
Aug 30, 2011 | HP LaserJet M4345 MultiFunction Printer
120.07 Service Fuser Error
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Jan 04, 2010 | Lexmark C530dn Laser Printer
How to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
Hp 4si
Your post is correct that error 53 refers to bad memory board or at times defective SIMM only. Since you have replaced them and no change, you may want to try to do a Cold Reset of the printer. This is done by powering on the printer while holding down the GO or Online button. Additionally, you may want to check/reset your NVRAM settings which can be done manually through the Service Mode.
This page lists most of the HP Laser Printer error codes. This link displays most HP LaserJets - Cold Reset Instructions.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | HP LaserJet 4si Printer
HP Laserjet Pro 400 Mfp M425dn Multifunction Laser Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
