Question about Acer Aspire 5100 Notebook
Test failure comp says media test failure exiting pxe rom
SOURCE:
IB4G2008
  • 3587 Answers
SOURCE: media test failure
sounds like your hard drive is unhappy..can you boot from recovery disk?
Posted on Mar 13, 2008
ohms
  • 1879 Answers
SOURCE: PXE-E61: Media test failure, check cable
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Posted on Aug 31, 2008
zabolyx
  • 38 Answers
SOURCE: comp won't boot
This could also happen if the hard drive is dead and trying to boot the next item or the BIOS has the Netboot option set as the first boot device.
Jump into your BIOS and make sure that the boot order is CDROM then USB then HDD. Then try again. Let us know what happens.
Posted on Apr 02, 2009
bob_computer
  • 3153 Answers
SOURCE: aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Posted on Sep 28, 2009
Testimonial: "I found an internal disconectet cabel fixing it solved the bootproblem"
pgh_pa_guy
  • 2992 Answers
SOURCE: can t boot up no disk to do so , broadcom undi
That message is coming from the motherboard. What it means is that your operating system wasn't found and the computer is trying to boot from a network. Because the network boot failed, you get the mysterious message.
This is happening because the computer can't read from the hard drive. It may be because the hard drive is bad or has been affected by a virus. Or its connection to the motherboard may have worked loose. Open the drive access cover and make sure the drive is firmly connected and try restarting your computer. If you still have the same trouble you'll need to have the hard drive or system board checked out.
Posted on Mar 01, 2010
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Dell Computers & Internet
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
When trying to reboot I'm getting this pxe-e61: media failure
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
Message saying media test failure, exiting pXE ROM and operating system not found. Cannot get anywhere thereafter. can get into F12 and F2 at startup,
Sounds like your hard drive died. If hard drive is dead you wont be able to get into anything but the bios. Hold down the CTRL key when computer starts and dont let go and try to force it into going into bios for you.
Mar 04, 2010 | Dell Inspiron Mini 10 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Comp won't boot
Apr 02, 2009 | Acer Aspire 5315-2153 Notebook
Aug 31, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5100 Notebook Logo
149 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
