My Sony DAV-S800 shows protect on display. What I must do?
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: sony dav-dz100
That means you have a bad speaker, speaker wire, or a componet in the output stage of the amp blew out. First thing to try is to disconnect all the speaker, Turn on the unit. If it still reads the same, you have a problem with the amp. these are solid state units and have no user replacable parts inside of them.. You will need to have it serviced or get a new unit, as to have these repaired or even estimated these days is very costly. Good Luck Please dont forget to rate this thread.
Posted on Nov 25, 2006
SOURCE: PROTECT UNPLUG
This is a common problem with sony it means unplug me or i will explode, it is a protection of the heat sync and usually means that a cooling fan has shorted out. If under gurentee return to Sony for repair if not under guranebntee as is generally the case check on the net for a replacement fan motor - as far as i know sony were sourcing thier fanns from Sunon there is a German based headquarters - just google sunon europe
Posted on Aug 12, 2007
dunnbiker
  • 8546 Answers
SOURCE: I have an error on the display screen which say's
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 16, 2011
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Display shows "push power protection"-DVD home theater system
there is a short in the amp that needs to be repaired before the unit will operate correctly.
Feb 12, 2013 | Sony DAV DZ150K DVD Home Theatre Music...
My Sony DAV DZ860W shows Push Power Protection fault message
http://www.avsforum.com/t/944637/sony-dav-hdx466-push-power-protector-flashing-on-display
Feb 09, 2011 | Sony Audio Players & Recorders
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
Nov 24, 2008 | Audio Players & Recorders
Protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Apr 09, 2008 | Sony DAV-S400 System
Picture distortion. Sound fine
Dont worry andysenny, Just give your dvd player for general service, these small problems will be rectified.
Feb 10, 2008 | Sony DAV-SC8 System
PROTECT UNPLUG
Aug 09, 2007 | Sony DAV-DZ100 System
103 people viewed this question
 Grubhead
Grubhead
