Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
Minolta ep 3000 error code c0000 - Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
2 Suggested Answers
  • 15 Answers
SOURCE: cannot reset minolta EP 3000
HI U can try [meter counter an pot stop 00 stop 0 1 +counter+trabol] Ucan see an fix UR error
Posted on Jan 15, 2010
Display error co500. Please help?
Open the front door, with power on. upper left small access cover remove and press trouble reset switch if the code comes back DO NOT RESET means a problem with the fuser (The hot Part) it can catch on fire that will ruin a perfectly good day. Have a tech come out look at it. He need to be old school that is a legacy Minolta machine, Now KonicaMinolta. For parts try this site.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Parts such as fuser lamp, thermistor and thermostat
Jun 17, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Access code needed
Access to what service mode or admin mode, pin#
Mar 29, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
EP 3000 ERROR CODE COO10
Main Motor, remove the fuser and check the gears, also check the gears that are located in the back of the copier where pulled the fuser from. Also check the drum developer units
Jun 09, 2014 | Konica Minolta Office Equipment & Supplies
Di450 Minolta Code 2510 erreur C0000
The C0000 code is that the Fusing Unit (The HOT Part) has a motor and it can not turn or is burned out do jam or gear problems. Could not find anything about 2510
Jan 22, 2014 | Minolta DiALTA Di183 Copier
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Apr 18, 2012 | Minolta Office Equipment & Supplies
Error code C0000
Main motor not turning. Check for a major paper jam in the fuser unit. Open the front door and on the left side is the fuser assembly. Push in the green knob and turn the fuser. It should turn rather easily. If not it is jammed. That is the most common cause. Other than that you would need a technician to determine what assembly in the machine that has locked up and thus preventing the main motor from turning.
Nov 23, 2011 | Minolta EP4000/5000 CS/PRO Copier
Error code c0000 in bizhub 210
Error code c0000 means imaging unit drive motor is not working or imaging unit get hard so its better to call a service representative.
Jul 07, 2010 | Konica Minolta bizhub 180 All-In-One...
Cannot reset minolta EP 3000
Oct 15, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
106 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
