Setting the clock on the remote
I need to reset the clock on the remote. All the manuals tell me how to set the timer, but not the clock....
  • Anonymous Feb 03, 2009
    I have the same problem
On the back side of remote .remove the cover on battery slot and u will find a black coloured one which u have to press with pen and set time from there
Posted on Jan 12, 2009
Setting the clock and timer on a 102E5
RTM. Read the Manual. You can Google the make, model and the word manual and you should find a .pdf file for the manual that you can save to your computer for future reference.
Feb 02, 2015 | Hardware & Accessories
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
Dec 11, 2014 | Hardware & Accessories
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
Panasonic =iv NV-MV40 , how to set the clock please
You can download the user manual for free from the Panasonic website.
Apr 03, 2011 | Televison & Video
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
Reset lamp clock
you need to reset lamp timer this is to tell set it now has new lamp i have the information at my shop as soon as i can , I will up date this with how to reset timer.
Dec 29, 2007 | Zenith D52WLCD 52" Rear Projection...
Program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Jul 26, 2007 | Panasonic PV-DM2093 Triple Play 20 in....
Setting the clock
No I'm sorry to say. but you will need to get an original replacement remote to adjust the clock and or the timer functions. good Luck
Apr 06, 2007 | Panasonic NV-SJ500 VHS VCR
Alarm clock radio feature
Before you do anything else, Cancel the Timer setting, which is activating the machine to start Playing in the afternoon. You will need the machine's Remote for this. On the Remote, Press TIMER repeatedly, while pressing SHIFT, till the Clock Symbol disappears from the Front Display. Now if you have to reset the Timer to play the machine at a different time - early morning, as you desire, follow these steps. First You have to make sure that the clock is set to the correct Time.Is it? Fine. If it is not,read trhe Owner's Manual and set it to the correct Time. Take note that you mark the AM or PM funtion properly. After the time is set correctly, You gotta set the clock to Switch On the set at a designated time in the morning. Follow the "Setting the Timer" instructions in the Manual to do so. Please do make the effort. I am here to help you, but I also do not encourage spoon feeding. You havta to some work yourself too. If you are still unable to do so, mail me at guptapravin@hotmail.com, and I shall send you step - by - step instructions Good Luck!
Sep 19, 2006 | Aiwa NSX-AJ310 Shelf System
Heating & Cooling Logo
296 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
