Question about Foxconn P4M800P7MA-RS2 Motherboard
My comp wont start and i think it may be an issue with ram initially my ddr2 couldnt hold firmly in the slot and i had toimprovise
  • bashmude Jan 19, 2009
    thanx for ur help but i still dont hear no beeps the comp goes on i.e fans running etc but nothing happens would be gratefull for more advice
  • whayne1 May 11, 2010
    You may have broke it fella
    Guru:
  • 859 Answers
Thanks for choosing FixYa.
If your RAM was bad or not inserted correctly you would hear four beeps in rapid succession at bootup.
If you have to force a RAM module into place this is not a good sign. Sometimes it is hard to get a RAM module to seat. But so long as you have it aligned correctly you should be okay using force to seat it so long as the clamps lock on the RAM module.
So, if you are not hearing any beeps at bootup and you are using only one RAM module, you probably need to place the single RAM module in a particular slot. You either have two or four slots. In either case when using one RAM module you should move it to another slot or reread your manual that states clearly the RAM module mapping and points out which slot to insert when you are only using a single module.
Thanks for using FixYa,
Worldvet
Advise me of any problems you continue to have. Just use the comment box below this to reply. I will get an email alert and will reply at my earliest. We all run our own business and are not always available to reply quickly.
Posted on Jan 12, 2009
  • Glenn Rogers
    Glenn Rogers Jan 19, 2009
    The RAM modules are often very close to the main power plug from the power supply. It has a release clip. Close the cip and pull up on the main power plug. Make sure the power supply is off or you have unplugged the power cord first. After removing the power plug at the main system board, reinsert it and try again.
    The only other explanation, should you continue to have no response, no fans, etc. Is that the power supply killed itself to protect your system. This happens. These don't cost a great deal of money, you only want to make certain the values are the same for your replacement power supply. If your's is 450Watts, get a 450Watt or larger. That's if you need one.
    Unplug your PC, remove the main power attachement on the motherboard and then reinsert it. Plug your PC back in and try again.
    Regards, and ready to help.
    Worldvet
Hello. I can't find any indication about my RAM. I have a Packard Bell Easy Note, model MX52, and i want to replace my RAM but i dont found any indication on withch memories should i use. TK...
One good and easy way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for each slot and the total capacity for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
I hope that was helpful to you, good luck.
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Joe.
Aug 12, 2011 | Computers & Internet
Look i have bought a foxconn mother board from ebay and it says its ddr2 but i have ddr in it and the ddr2 wont fit is ther something im doing wrong will u send me a pic of this board so i can see what it...
i think you have placed ram in worng slot , check this pic to set ram in correct sport immortal4u.jpeg
this is ram slot which have two hoke at both end try to fit your ddr2 in this base, surely it will fit , actully all ddr , ddr1 , ddr2 wil fit in most of board but performance will be vary, so you board support ddr2 ram mean fit the name in this slot.
GOOD luck
Dec 31, 2010 | Computers & Internet
Can I upgrade my Ram on Gateway Desktop . I have 512mb, 2.0MHz. It's a good computer that I would upgrade for a project.
Hello
Number of Slots:4
Slot 1 Slot 2 Slot 3 Slot 4 Each memory slot can hold DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 1GB per slot.
Not to exceed manufacturer supported memory
Good Luck, and do rate the solution if got help
Dec 24, 2010 | Gateway GT5220 PC Desktop
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Wayne
Sep 09, 2009 | ASUS P5VD2-MX SE Motherboard
Asus p5 vdc-x motherboard not recognizing ddr2
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
Long beep on start up
refix your ram if still facing problem try alls slot one by one.
If u start your computer with 2 ram then only start it with new one also some times frequency poblem between ram
May 05, 2009 | Computers & Internet
Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card? -jayvee_yao@yahoo.com
Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
best regards
Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
ECS 915-A(1.1) Ram Reading Issues
Is it a single ram module or dual ie. 2x 1gig ddr2 533?
What motherboard are you running?
Is it possible that you've given a static charge out while handling the ram?
Feb 27, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
RAM COMPATIBILITY
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
83
Jan 24, 2008 | Intel D845GVSR Motherboard
Foxconn P4M800P7MA-RS2 Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
