Question about E-Machines T5082 PC Desktop
Unable to run in dual channel mode
Just purchased Kingston 2gb kit (PC2-4200 CL4 240-Pin DIMM kit) for my computer which is the emachines t5082 model. I used the memory configuator and this is what it reccommended. It says that it would run in dual channel and that my computer supported dual channel. Well, the computer recognizes the full 2g memory, but only runs in single channel. Is there something I am doing wrong? Is there a Bios update?
Thanks!
  • wingeier Jan 12, 2009
    Thank you so much. I will be contacting Kingston.
    I did however contact them a week ago because they sent me a 2gb kit pc2-5300 CL5 240-Pin DIMM kit that I installed and was having the same problem. They sent me another (different speed) kit as posted above. I do not think I am doing anything wrong here. Is there something I should be looking for? Am I buying the wrong memory?
    right on!
    Fix ya rating it is!
    I will call and see what we can find out.
    I will update
    My other question is, I have two of these same model computers (my mom also has one) I bought them at the same time. I am having this same issue with both of these computers, so I do not think it is the mother board, unless it came from the factory with this problem. It has been over a year so emachines was little to no help when I contacted them. They told me I had to have a technician come to my house to resolve the problem on my expense. I will keep trying and searching.
    Update to follow
    Thanks!
    Guru:
  • 859 Answers
Welcome to FixYa.
Currently there is no bios update for your system. In the course of operating my business I have seen dual channel RAM run in single channel as a result of the CPU in use. This should not be the case in your model though.
I would encourage you to speak with a Kingston rep to solve this problem as you are well within warranty.
Toll-Free:+1 (877) KINGSTON
+1 (877) 546-4786
Here is the Contact Page for Kingston if you are outside the U.S.
http://www.kingston.com/company/contact.asp
They will be able to resolve your issue which has to be related to the RAM you purchased. Even though the memory configurator pointed you to this RAM, it may not be functioning correctly and should be replaced or upgraded to a more specific RAM model.
Regards, thanks for choosing FixYa.
Worldvet
Posted on Jan 12, 2009
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Jan 12, 2009
    No, you are not out of the operating specs for your system board on this PC.
    More often we used to see this lack of dual channel related to the CPU or what we call the Northbridge controller. On the main board there is also a memory controller chip. Sadly though, E machines does not have a bios update as yet for this machine.
    To answer your question on whether you should use another RAM maker, its a toss up. Kingston is one of the better companies who stands up for their product and is easy to actually phone for help.
    The other company to try would be Crucial, also easy to reach and get assistance. Click on the previous link. They have live chat.
    They make the Micron Brand RAM for the U.S. Government.
    So, yes you could try another RAM maker and that would be sensible. If you still have no positive results, my guess is in your motherboard from Emachines. Should you contact Emachines over this and are insistent they will dispatch a tech to come to your house and replace the main motheroboard.
    Contact Emachines web page here. They do not have toll free numbers.
    By the way, the rank of vote you apply is sort of like how we get paid, its a ranking system. I appreciate the helpful, but would really appreciate a FixYa rating if you do not mind. Thanks.
  • Glenn Rogers
    Thank for the extra diamond. I do appreciates. We all appreciate that gestrue.
    Emachines has their motherboards made by a company in Taiwan who specifically builds it and the Bios for them. Same with Gateway.
    This, as I stated should be rectified by Emachines.
    What can you do? If after this additional contact with Emachines you still feel you have not received service, go to bbb.org and register with them in order to log a complaint. That will get you some action.
    Regards,
    Worldvet
  • Glenn Rogers
    With respect to your question about buying the right memory. Some memory is single sided and double sided and the motherboard can in some cases deal with one and not the other.
    This is a question for Emachines and Kingstor or Crucial. They know all about it and there is normally a starement as to using single sideed vs doiuble sided.
    Double sided means there are memory chips on both sides of the RAM module and single sided on only one side. That can cause problems.
    I tend to thing that its a problem for Emachine as their documentation is very weak on this common issue for we builders.
    Worldvet
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
I want to upgrade my computer specs... hope you can help me.. CPU: intel core2 duo E4600 2.4Ghz/800Mhz/2mb L2 cache/65MOnm MOBO: elite 945GCT -M2/1333 (v1.0), 1945GC/C2D/1333MHZ/DDR2 667/PCI-E memory:...
If you are a "gamer" and you have 1GB of RAM, and you have Windows XP, you probably need more RAM.
If you are a "gamer" and you have 1GB of RAM, and you have Windows Vista or Windows 7, you DEFINITELY need more RAM.
Some motherboards support "dual-channel" mode, when you have 2 or 4 _IDENTICAL_ sticks of RAM. What happens is that each byte written to the RAM is "split" into 2 halves; one half is written to the 'A' stick of RAM, while, simultaneously, the other half is written to the 'B' stick of RAM. Obviously, this takes 4 "cycles" of the RAM, rather than taking 8 "cycles", if there was only one stick of RAM. So, your RAM seems to run at "double-speed".
So, when you buy more RAM, either try very hard to "match" your current 1GB stick of RAM, or purchase a "2GB dual-channel kit", or two "2GB dual-channel kits", to upgrade to 2GB (or 4GB) of RAM.
Aug 04, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Intel 102 motherboard
If your Intel motherboards model number is D102GGC2 you can run up to 2GB of memory. Two 240-pin SDRAM Dual Inline Memory Module (DIMM) sockets, 533/400 MHz single channel DDR2 SDRAM interface Designed to support up to 2 GB of system memory Use one GB in each DIMM slot for the total of 1GB. (See manual link below. http://download.intel.com/support/motherboards/desktop/d102ggc2/sb/d4798502_en.pdf Cheers! Mike
Jun 04, 2009 | Intel Computers & Internet
Compaq presario sr2050nx wont recognize Kingston Valueram 1gb 533mhz ddr2 sdram 240 pin DIMM in conjunction with the original RAM, but can recognize each one individually
(PC2-4200) correct 533MHz you can go up to 2GB max, they should be matching ...non buff, non registered, no ecc
Modules must be installed in pairs for Dual Channel mode.
This tell you what you need, I am not sure why.
It would seem to me if they were equal in all aspects ...???
Hope this helps...please leave rating...thank you kindly
Apr 30, 2009 | HP Compaq Presario SR2050NX PC Desktop
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
E-Machines T5082 PC Desktop Logo
501 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
