Question about Casio Exilim EX-Z50 Digital Camera
Casio ex-z50 lens doesn't open
After pressing power button, motor sounds, lens makes slight movement, but stays locked in, doesn't extend out.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Posted on Dec 06, 2012
  • 3 Answers
SOURCE: Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Posted on Jun 28, 2007
  • 374 Answers
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Posted on Mar 30, 2008
SOURCE: Exilim EX s600 lens grinding on extension
I had the same problem and I left it on the charger over night and in the morning I turned it on and the lens extended smoothly with no noise and is now focusing
Posted on Nov 25, 2008
SOURCE: casio exilim ex-z60 lens error retry power
the same thing happened to me &nd i took it apart &nd nothing happened .
Posted on Jul 20, 2009
  • 102366 Answers
SOURCE: lens error with Casio Exilim EX-Z80 and makes a weird buxxing sound please I need help
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
My camera Casio EX-Z800 has a lens error
Digital cameras are extremely popular. However, with many cameras you will at one point be faced with a lens problem, more commonly known as the E18 error or lens error. It manifests by thethe screen. The lens either gets stuck in the extended position, or it tries to extend, fails, and then retracts. Here are ideas on how to repair the problem:
1. Call the manufacturer and/or visit their website to see if they will repair you camera. There arewill just send it to the manufacturer and then charge you more than what the manufacturer would charge. If you are in warranty, don't go to a store, call the manufacturer first.
Repair it yourself only if your camera is out of warranty, or if the manufacturer refuses to repair it for free, which may happen if, for example, they decide the damage was caused by abuse or neglect.
2. First, make sure your camera has fresh batteries and it is in recording mode.
3. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
4. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
5. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
6. Place the camera on it's back and look at the lens from its side. It may look slightly crooked. If this is the case, power up your camera and apply pressure gently to the side of the lens to center it. It should then extend fully.
7. Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
8. If the lens doesn't extend at all or it extends and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a click as it pops back in place. Power the camera on.
9. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a click. If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
10. If none of the methods work, you can dismantle the camera and try to clean the lens. A good guide on dismantling Canon digital cameras with pictures can be found in the external links.
Check this article fixing-lens-error-on-digital-camera.
Keep us updated and remember to rate this answer.
May 20, 2011 | Casio EX-Z800 Digital Camera
Compact digital camera lens assembly jammed after dropping
i worked as service engineer on life support equipment for 15 years but alas my cannon g10 with above symptoms didnt make it back together .... never start without a manual to assit you ....adrian
Dec 27, 2009 | Casio Exilim EX-S500 Digital Camera
My casio exlim camera lens dropped and now my camera won't turn on nor take pictures
you've got a problem with your camera power management system. if you can open it try to follow where cables nor conductors from battery are going and check them physically.
Apr 28, 2009 | Casio Exilim EX-Z50 Digital Camera
Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Apr 25, 2009 | Casio Exilim EX-Z40 Digital Camera
Lens Error
Dec 27, 2008 | Casio Exilim EX-Z50 Digital Camera
Wont turn on
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Apr 20, 2008 | Casio Exilim EX-Z50 Digital Camera
Casio EX-Z50 digital camera - will not 'start' i.e. lens will not extend
Feb 24, 2008 | Casio Exilim EX-Z50 Digital Camera
Lens issue with my Casio EX-Z50
I don't believe a "lens error" can be fixed at home. That is something that is going to have to be sent in. Sometimes if repairing the camera costs more than what it's worth Casio will offer you a trade up to a different model. Call the repairs dept and ask them about that program. Their number is 800-706-2534 and keep choosing option 1.
Jan 29, 2007 | Casio Exilim EX-Z50 Digital Camera
Casio Exilim EX-Z50 Digital Camera Logo
59 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
