Pci simple communications controller FOR OPTIPLEX 7010 windows xp
Pci simple communications controller driver
johnhercus26
  • 104 Answers
SOURCE: I need drivers for PCI Simple Communication
download 50000 pc drivers for xp from torrentz/mininova make sure u have either bitlord or utorrent installed on ure system 1st when download is done move folder from in downloads to your desktop now open up device manager goto the pci device needing driver should have yellow question mark at it and tell the pc to search your desktop and it should hopefully find it in the folder when done delete folder and make sure your not running utorrent/bitlord as you will be shareing this file with others
Posted on Oct 09, 2009
  • 102 Answers
SOURCE: PCI simple Communication Controller
Drivers are here:
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=96027&lc=en&cc=us&dlc=
Just click evo d510 cmt, then download drivers and software.
You should now be at a page that lists all of hp's drivers for your system.
I think PCI simple Communication Controller would be your modem, which I saw on that page, and also the driver for your ethernet controller.
Posted on Aug 02, 2008
ashish13
  • 75 Answers
SOURCE: no pci simple communications controller driver
you will need to install the modem driver please check the model no and the modem that you have on the system, select appropriate os and download the appropriate driver from dell support site. Dell support
If you can figure out which modem is in your system and you haven't ever replaced it please call Dell tech support and provide your system service tag they will be able to help you with this aslo you can check your system configuration on the site itself if you have the service tag ready. check dell system configuration
enter the service tag and check under original system configuration will be listed as MDM
Posted on Feb 11, 2009
  • 2692 Answers
SOURCE: Emachines driver
E-Machine Web-link for your model:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6216
Posted on Feb 16, 2009
fayazbpoint
SOURCE: Cant find PCI Simple Communications Controller drivers even at HP.com
Posted on Jan 08, 2012
Firewire port usff 7010
If you're asking if a Dell OptiPlex 7010 USFF will support Firewire the answer is No...Unless you purchase and install a Firewire card
The OptiPlex 7010 USFF has the following external connections:
  • Front Panel: one microphone connector and one headphone connector
  • Back Panel: one line-out connector and one line-in/microphone connector
  • Network Adapter: one RJ45 connector
  • Serial: one 9-pin connector; 16550 C compatible
  • USB 3.0: Back Panel - 2
  • Video: 15-pin VGA connector
  • 20-pin DisplayPort connectors - 2
I don't recommend any USB to Firewire convertors but if you can find a Firewire Convertor PCI Express Card you can try installing it but remember the USFF has only one Mini PCI Express 52-pin connector, I've highlighted a possible product. It allows for Firewire 800 speeds. The included optional internal Molex power connection is only required if your Firewire device doesn't have its own power adapter
May 07, 2014 | Dell Optiplex 7010 500gb Usff Ultra Small...
Restart when plug in
start in safe mode,,,then go to device manager,,,right click all processor the disable ,,,after restart your computer normally
Dec 07, 2017 | HIS RADEON HD 4670, (1 GB) AGP Video Card
Pci simple communications controller could not find a driver so there's no internet, board is an Asus p5smxse with 2 chipsets, one on the north and the other on the south. sis 968 and sis 671fx
Enter your bios and make sure you're lan is [Enabled].
Open the link provided below;
http://www.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6&content=download
Choose you're operating system from the drop down menu.
There is one LAN driver, Sis Driver V2.0.1039.1070 for Windows 2000/XP/2003/XP 64bit/2003 64bit. Create a folder on your desktop and name it LAN. Download the LAN driver into the LAN folder. Uncompress the zip file, keep the uncompressed file within the LAN folder. Open windows device manager. Find the pci simple communications controller. Right click on it once. From the pop-up menu left click, update driver. Follow windows instructions. Find the Lan folder on you're desktop and open it. Left click once on the newely created Lan folder so it is high lighted. Click OK. Windows will find the correct software and install it for you. When finished restart you're system. Check windows update for hardware and software updates after windows restarts.
More often than not (pci simple communications controller) points to an audio driver missing but LAN controllers are included.
Cheers!
Mike
Jan 09, 2010 | ASUS Computers & Internet
Did a clean install of windows xp SP2 and am unable to connect to the LAN connection between the NIC board and the broadband modem. Error message tells me simple communications controller is missing. What...
Hello.
When you performed the Windows XP install, not all the drivers were available and installed.
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Dec 21, 2009 | Office Equipment & Supplies
I cannot use internet for my modem driver has ? i need driver for pci simple communication controller. please help me.. so that i could use internet again. i'm using windows xp.
Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
Nov 29, 2009 | SimpleTech SimpleStation (STI-PNPR/PCI) PC...
PCI simply communication controller
Go to the Sharp WEB site to download the Windows XP or Vista driver for the device you require. If you have problems identifying the driver you require, send an e-mail to their support. Use this link to get to Sharp support. http://www.sharpusa.com/products/support/0,2309,,00.html
Jun 09, 2009 | Sharp Actius AV18 Notebook
Upon reinstallation of OS the device manager is showing that the PCI Simple Communication Controller has an exclamation point...I am stumped and cannot get this to correct...Please help...oh...windows XP...
This means that you do not have a driver for this device. The link below leads to download location on dells website for your machine. Start by installing the chipset driver. If that doesn't fix it, try the modem and network driver sections. without looking at your machine I can't be sure which driver you are missing. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid=
Jun 03, 2009 | Dell OptiPlex™ GX270 PC Desktop
Computers & Internet Logo
2,466 people viewed this question
David Payne
David Payne
