CODES DE PANNE CANON IR 1018 E808 - Office Equipment & Supplies
  • 66 Answers
SOURCE: my canon ir 1018 displays this error code e808 and does not print
has the machine been serviced recently? if not, unplug machine for 10 mins, then plug back in. if the code comes back the fuser assembly will need to be replaced.
Posted on Apr 13, 2009
  • 153 Answers
SOURCE: Firmware for canon iR 1018
you need a special service tool to load the firmware to the copier and usually only canon sevice technicians have access to it,
you may need to call a canon agent service centre
Posted on Jun 01, 2009
  • 1297 Answers
SOURCE: code de panne E000584-0003 for canon image runner
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty.
For the reset : COPIER-FUNCTION-CLEAR-ERR.
Posted on Sep 01, 2009
SOURCE: mon probleme de canon ir6020i
I have gestener ir6020 copier & it dispay E1000 error tks
Posted on Nov 05, 2010
SOURCE: i have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
Posted on Nov 22, 2010
I have Canon iR 2016 it show E808 code error
That error is related with the fixing unit. Check the connectors or replace the fixing film assy
Mar 25, 2015 | Canon IR2016J
Give solution for canon ir 5050 error code e808-02
See here.
http://www.copytechnet.com/forums/canon/53715-ir5075-e808-002-a.html
Jun 19, 2014 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir 2525 service manual & parts catalog
Please refer your request directly to Canon
Apr 18, 2013 | Canon IR 2525 Digital Copier
ERROAR E001 AND E808
u can clear E001 in the service mode Press * 28 * go to clear press OK then err press OK . and the E808 is the cooling fan malfunction .it can be because of the erratic power fluctuations or damaged fan.
and the if E001 happens during copying then u have to check the fusing unit as sometimes the pressure roller bush gets misplaced from original position causing jam and code
Aug 03, 2011 | Canon iR 2016i Black and White Copier
I have Canon iR 2020 it show E808 code error
conon ir2020i can not innitiallise asking to switch off and on the main power switch
Jan 06, 2011 | Canon iR 2016i Black and White Copier
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
E808 0000 Fixing drive circuit failure
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
May 29, 2010 | Canon iR 2016i Black and White Copier
My canon ir 1018 displays this error code e808 and does not print
Apr 13, 2009 | Canon imageRUNNER 1023iF Black and White...
22 people viewed this question
jasbo
jasbo
