Question about Ovens
Oven controls allenzi oven
`what is the meaning of the symbols on the oven control knob
  • 250 Answers
SOURCE: Because I haven't got a manual, and the oven is
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Posted on Dec 12, 2009
SOURCE: Canon Carrick LPG cooker-failure of
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email info@music-works.uk.com for a JPG.
Posted on Jan 08, 2011
MNTECH
  • 1543 Answers
SOURCE: The only way I can get the oven on our GE XL44 gas
Replace the oven igniter, part number WB13K21 located under the oven floor.
Posted on Feb 19, 2011
SOURCE: I have a new Diplomat
My ovens not working and don't know what picture to put it on
Posted on Mar 10, 2011
  • 11 Answers
SOURCE: don't have instruction booklet - need to know
Hi, if you follow this link below, you can download your user guide, which will let you know what the settings are.
http://www.manualshark.org/m/aeg-b8871-4-a-instruction-manual-u25391-product-number-code-944185215-10006/
Posted on Sep 07, 2011
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
Fan symbols.
fan symbols mean that the fan is supposed to be working or that knob controls the fan operation
Jun 17, 2013 | Ovens
Hi I have just moved into a house with an Allenzi upright stove/oven and the oven functions have rubbed off. Is there anywhere I can get a new manual for it or a photo of the dial? I keep burning the...
http://www.allenzi.com.au/downloads/AWEM9U.pdf
Copy and paste into your browser for the oven download manual. Please rate my solution it is how i earn my achievements. Thanks in advance
Apr 13, 2012 | Ovens
I was baking and steam was coming out of the stove area right below the knobs? what do I do about that? is it broken or is there a setting I can change?
Steam is a natural product of baking but the heat from an oven rising directly to the control knobs on any cooker is unacceptable. Those knobs are not decorative mouldings to make the appliance look pretty, they are a means of controlling the gas valves! I suggest you check that your appliance is standing square upright and level. If it is then I think perhaps you might replace the oven door seal.
Sep 19, 2011 | Tappan 30IN ELEC IGNa Oven
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
May 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
Dec 10, 2009 | Stoves 720EF Electric Double Oven
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
