Question about Garden
What is the petrol to oil ratio for a morrison BC230B trimmer???
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
  • 246 Answers
SOURCE: no user manual
Hello:
Most 2 Cycle Engines use a 32:1 or 40:1 Fuel Mix Ratio.
The Newer 2 Cycle Engines use a 40:1 or 50:1 Fuel Ratio.
For Better Performance and to be sure you have Plenty of Oil to the Engines Internal Components, I Suggest (and I Use) a 32:1 Ratio in All my Equipment except for Post Hole Diggers.
Post Hole Diggers Use a 25:1 Fuel Ratio.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • 6 Answers
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Posted on Jun 19, 2009
dontbother10
  • 2220 Answers
SOURCE: what is the correct ratio gas to oil for my stihl fs 66 trimmer
Use a quality 2 cycle oil and mix it to the oil manufacturer's recommended ratio. Today it is usually 50:1.
Fuel in the USA contains ethanol; try to use up your mix in a month or less. HTH
Lou
Posted on Sep 07, 2009
  • 468 Answers
SOURCE: GAS TO OIL RATIO
Homelite products are 40:1 gas to oil ratio
Posted on May 28, 2010
Testimonial: "QUICK & PRECISE!! A GREAT HELP, & GOOD WAY TO FIND ANSWERS."
I hve a Tanaka edge trimmer, I haven't used for long time, I forget how to mix the petrol. Please help.
The fuel to oil ratio is 50:1
100ml of 2stroke oil in 5L of petrol
Apr 19, 2016 | Garden
Hi, I'm having problems starting my new morrison bc230b weedeater... I think whats happened is the wrong fuel was put in it..(no oil mixed) .is there a quick fix? thanks
hi there
walkersworld
if you have run the unit with no oil in the mix ie straight petrol
you will have damaged the piston / rings / bore - do a compression check - if its quite low
check - remove the muffler and check for score marks on piston and rings and bore
if so , the unit may not be worth repair , because compression will be lost past damaged rings
and with damage on piston more scoring / damage will occur
so answer to is there a quick fix - no especaily if what find when you look up the ex port at piston / rings/bore
have a look
sorry for bad news
pauly46
May 31, 2011 | Garden
Oil/petrol mixture for GPHS 26cc gardenline hedge trimmer
Petrol / oil should be in ratio 50 to 1
Apr 13, 2011 | Garden
Oil to petrol ratio?Thanks Partner B300BX strimmer
If you are using stihl oil then the mix is 50:1
Jul 31, 2010 | Husqvarna Garden
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
What mix of 2 stroke oil do I use for a Stihl hedge trimmer, in other words how much 2 stroke oil do I put into 5 litres of petrol. Thanks.
if using top quality 2 stroke oil
you put 100 mils of oil into 5 litre container and add 5 litres of fuel only that is 50:1 petrol oil ratio
cheers pauly46
May 29, 2010 | Garden
What oil ratio to petrol do I use?
40:1 is the recommended ratio for this type of engine.
If you cannot measure accurately you should tend towards more oil rather than less. That will protect your engine and the only downside will be a slightly smokier exhaust and possible oiling of the plug over time.
Apr 10, 2010 | Husqvarna 28cc Gas Line Trimmer
Do I just fill up my petrol strimmer with petrol, or do I have to put in some two stroke oil as well?
yes 2 stroke in weedeaters, trimmers, etc, look on the cap, or sticker and see the gas/oil mix ratio
Jun 07, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
