Question about Dell Optiplex 755 Desktop Desktop Computer
" Alert! unsupported memory configuration. Please populate DIMM1. Strike the F1 key to continue, F2 to run the setup utility Press F5 to run onboard diagnostics"
So what am doing now....
sandrew
  • 2961 Answers
SOURCE: Plug & Play Configuration Error
this may not be your ethernet card that is causing the fault, it is probably a flat cmos battery (CR2032) disc shaped battery normally close to the memory slots. This will need to be replaced, it's a simple job, just remove side panel of tower and flip the battery out and replace, probably cost $3.00. You will then be prompted on the next boot up to press f2 to set the date and time and then save and exit again for a reboot
Posted on May 29, 2007
SOURCE: strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Posted on Dec 24, 2009
  • 49 Answers
SOURCE: At start up i get Alert! previous Fan Failure
One of the cooling fans inside the case of the computer (where you put cd's in, and plug all your cords in. There will be at least 2 fans in your unit, but probably 3. The fans keep the computer running cool, preventing damage to the sensitve chips and electronics inside your computer. There is a big fan near the top of the case, this is for the power supply. This is probably NOT the culprit. You can remove one side of the case by removing two of three screws. (dont be nervous, you wont wreck anything.) With the case off, turn the computer on and look for the fan that is not spinning. Turn the computer off. Check the wires running from the fan to the computer (should be three) two are for power, the third sends the signal to the comp telling it its speed and whether it is working or not. If everything checks out, then you just need a new fan. There are only two sizes, but you should be able to remove the fan by disconnecting the wires (mark where they went!!) and removing the phillips (star) screws that mount it to your case. Take the old fan to radio shack or a comp. suppy store and match it up. All computer fans are 12v with 3 connectors. You should be able to manage this repair yourself. You will not break anything, just be sure the power is off when you are removing the fan and take care not to slip and damage something when you are removing and installikng the fan.
Cheers
Jer
Posted on Jan 16, 2010
  • 707 Answers
SOURCE: Have a Dell XPS 600 problem. I am getting a
If you have another keyboard try swapping it out and see if it reads the new one. Also a stuck key could possibly cause this error. System battery message probably means you need a new battery for the motherboard. If you replace the battery get the new one before removing the old one. If you leave it out too long you can clear the CMOS
Posted on Oct 15, 2010
Testimonial: "Thanks alot!!! Very helpful. Thumbs up."
DKC011
  • 12 Answers
SOURCE: when start my pc it
Hi, You can try power drain first. Power off system , disconnect power and press and hold power button to discharge stored power, then remove memory module 1, then reseat it by inserting it with the levers extended to the sides and press down with thumbs until the levers snap in place vertically on their own. if no change, replace module. \quote While reseating the Memory Module please Handle with care. Quote/
Posted on Dec 29, 2010
Can this no picture be fixed?
Audiobook Literature & Fiction ยป Who Do You Love by Jennifer Weiner Epub.PDF free
An unforgettable story about true love, real life, and second chances...
Rachel Blum and Andy Landis are just eight years old when they meet one night in an ER waiting room. Born with a congenital heart defect, Rachel is a veteran of hospitals, and she's intrigued by the boy who shows up alone with a broken arm. He tells her his name. She tells him a story. After Andy's taken back to a doctor and Rachel's sent back to her bed, they think they'll never see each other again.
Download Link Below :
click here:>> http://download.epubpdf.mobi/who-do-you-love-by-jennifer-weiner/
Download Who Do You Love by Jennifer Weiner Ebook , Who Do You Love by Jennifer Weiner book Online, !!Best books!! For Readers, For Fans Who Do You Love by Jennifer Weiner Online Free EBook PDF, Read Who Do You Love by Jennifer Weiner Book Online Price
Download Who Do You Love by Jennifer Weiner Book Online Free Epub,!!Best books!! Buy Who Do You Love by Jennifer Weiner Book Online Free PDF, New books for female, Who Do You Love by Jennifer Weiner with ISBN Number!!Best books!! Buy Who Do You Love by Jennifer Weiner Book Online Free Audio,!!Best books!! Buy Who Do You Love by Jennifer Weiner Book Online Free, Who Do You Love by Jennifer Weiner Book Online.
Tags:
Free Who Do You Love by Jennifer Weiner epub download
Who Do You Love by Jennifer Weiner mobi download
Download Who Do You Love by Jennifer Weiner PDF Download
Free Who Do You Love by Jennifer Weiner PDF Download
Ebook Who Do You Love by Jennifer Weiner pdf download
Download Who Do You Love by Jennifer Weiner azw download
Free Who Do You Love by Jennifer Weiner kf8 download
Download Who Do You Love by Jennifer Weiner read online
[ePub]Who Do You Love by Jennifer Weiner
Free Who Do You Love by Jennifer Weiner ibook download
Neal Stephenson - Who Do You Love by Jennifer Weiner mobi download
Author Neal Stephenson - Who Do You Love by Jennifer Weiner for ipad
Ebook Who Do You Love by Jennifer Weiner buy cheap
Download Stephenson - Who Do You Love by Jennifer Weiner android
Download Who Do You Love by Jennifer Weiner by (Indigo Island Book 4) download ebooks for mobile
Neal Stephenson - Who Do You Love by Jennifer Weiner pdf download
Ebook Who Do You Love by Jennifer Weiner - Neal Stephenson amazon kindle
buy Who Do You Love by Jennifer Weiner
Read Who Do You Love by Jennifer Weiner android
Download Who Do You Love by Jennifer Weiner ePub
Ebook Who Do You Love by Jennifer Weiner txt download
Who Do You Love by Jennifer Weiner download
PDF!! Who Do You Love by Jennifer Weiner .doc download
Buy Stephenson Who Do You Love by Jennifer Weiner ebook download
Read Who Do You Love by Jennifer Weiner ebook download
Download Who Do You Love by Jennifer Weiner in PDF
Download Who Do You Love by Jennifer Weiner in ePubWho Do You Love by Jennifer Weiner PDF DownloadWho Do You Love by Jennifer Weiner ePub Download
Who Do You Love by Jennifer Weiner txt Download
Who Do You Love by Jennifer Weiner word Download
Released Who Do You Love by Jennifer Weiner read online
Download Who Do You Love by Jennifer Weiner kindle
Who Do You Love by Jennifer Weiner Epub Download
Download Who Do You Love by Jennifer Weiner ebook
Who Do You Love by Jennifer Weiner zip Download
Who Do You Love by Jennifer Weiner rar Download
Neal Who Do You Love by Jennifer Weiner PDF Download
PDF format Who Do You Love by Jennifer Weiner Pdf Format
Buy Who Do You Love by Jennifer Weiner android
download Who Do You Love by Jennifer Weiner ePub
Get Who Do You Love by Jennifer Weiner azw
Who Do You Love by Jennifer Weiner Download ePub PDF mobi
Sep 12, 2015 | Televison & Video
Instruction manual for pole pruner attachment
Do not use as a coaster.
Do not use to stabilize a wobbly table.
Your pole pruner is not edible.
Do not taunt your pole pruner.
Your pole pruner is not a parachute.
Do not feed your pole pruner after midnight.
Do not use pole pruner to commit armed robbery.
Do not name your pole pruner Carl.
Do not marry your pole pruner.
Do not turn your back on your pole pruner.
Jul 25, 2011 | Flamebrain Technologies WatchMe
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
Dell Optiplex 755 Desktop Desktop Computer  Logo
509 people viewed this question
Alun Cox
