Question about HP PSC 1315 All-In-One InkJet Printer
How to replace pickup roller on hp 1350 v
Its not picking up the paper
  • 54 Answers
SOURCE: My HP Laserjet 1000 printer
Cleaned the paper pickup unit gear & sensor, your problem will solve.
Thanks.
Posted on Mar 21, 2008
  • 138 Answers
SOURCE: Tray2 Paper emty message after swapping out tray2 pickup roller
Your problem is more than likely that the sensor lever is not properly positioned. You may also have dislodged the shaft from the drive gears (gears on right out side of carriage). Both are easy to do.
Here's a couple pictures of the exact positioning of the paper sensor positioning. It should freely flip up and fall back down with gravity. Remove the tray and check the flag that hangs down.
Just in case you have dislodged the shaft from the geartrain, here's a free copy of the HP Service manual for the printer that will walk you through disassembling the right side for re-mounting the shaft and holder clip for the shaft.
Hope that helps you. :)
If this resolves the issue, hit me with a Fixya! If not ask me further and I'll try and help you some more.
Posted on Sep 10, 2008
Joed911
  • 4338 Answers
SOURCE: replace the tray 2 pickup roller assembly
The tray two pickup roller is a roller in the front of the tray. Remove tray 2 and place it on a level work surface. Locate and open the cover that is
next to the roller in tray 2.
Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft.
Then you can slide the new roller back in.
CAUTION When you install this roller, make sure that it locks into place. Verify that the
roller is correctly oriented, and that the round, black spacer next to the roller is correctly
positioned against the locking pin on the shaft.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
FixinFax
  • 3085 Answers
SOURCE: HP Photosmart C6150. Rollers do not pick up paper
Remove the rear cover a reallly scrub the black rollers with isopropyl alcohol. Scrub HARD
Posted on Jun 11, 2009
  • 56 Answers
SOURCE: HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Posted on Oct 09, 2009
Rollers shaft remove
check printer's paper Pick-up Roller ( Insight of printer ).
Replace Paper Pickup Roller.
Nov 01, 2013 | HP LaserJet 3015 All-In-One Printer
My hp laserjet 1320 takes in more than one paper while printing, which get stuck.
Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Mar 28, 2013 | HP LaserJet 1320 Printer
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
I have an hp p3005 with the jam code 13.01.00. It has had the feed rollers and sep pads replaced. When it runs it appears to catch on the separation pad itself since it shows a small buckle in the middle...
Replaced seperation pad?. separation pad work is to block multiple paper feeding,but in yourcase paper not at all feeding means paper pickup roller not picking up the papers.replace both 2 & 3 paper pickup rollers..
See the snap shot,view from under.
Pickup roller( red)
Un lock to remove pick up roller(blue),observe the angle of the roller & same way insert new one other wise it wont fix..
Bee care full while removing roller, paper sensor flag should not distubed(yellow)
bee pateince dont do harsh..best of luck.
Oct 11, 2011 | HP LaserJet P3005 Printer
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
Error 13.01.00 hp 3005
Thank you for contacting FixYa with your printer inquiry.
This is usually a paper pickup error where paper pickup roller is not contacting the paper in the default paper tray or Pickup roller is worn smooth and not picking up the paper.
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding.
Solutions: Make sure the paper size adjuster in the tray (Paper Backstop) is against the paper and correctly set for paper size.
Paper roller slippage - Needs to be replaced. Order a new one. Clean with water or alcohol in the interim while waiting for replacement. Eliminate all the paper dust. Sometimes works.
Part Number: RL1-1370-000CN Paper pickup roller - Picks up media from the paper input tray.
Venders: http://partsurfer.hp.com/Search.aspx?SearchText=Q7814A - HP Parts Surfer
http://www.laserprinterservices.com/parts.html
https://www.partsnow.com/Forms/Login.aspx
http://www.thelaserguys.com/Printer-Error-Codes_ep_42.html
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet P3005n Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
My printer hp laser jet 1320 not picking the paper from the tray.
Can you hear if the roller mechanism is kicking in? If you hear the roller moving but the paper is not even starting up the path, it's probably a worn pickup roller. If the solenoid is firing but the roller isn't turning then the feed roller shafts clutch mech is probably worn/broken and needs replaced.
Dec 18, 2008 | HP LaserJet 1320n Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
HP 7110 printer paper rollers
usally when a printer picks up too many sheets the pickup rollers are dirty or covered with paper dust use a microfiber towel moistened with water or rubbing alcohol wipe them off then if it still picks up too many sheets the surface of the pickup roller is worn.replace pick up roller the printerworks .com may have parts or hp partSurfer.com
Oct 20, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP PSC 1315 All-In-One InkJet Printer Logo
165 people viewed this question
Seeker5211
Seeker5211
