Question about Acer Computers & Internet
Acer Aspire Z5761 desktop,Power supply fan has stopped working
SOURCE: Acer Aspire L100 will not power up
It's most likely not the power supply. I have a customer with the same problem. I used a power meter to see if the power supply worked and it checked out perfect. (You should still test it though, just in case.)
The only thing I can figure is a bad motherboard. Unfortunately, there's no visual signs of overheating, arc burns, or the like on this one to make it obvious... just one capacitor (the small one nearest to the power port) that has a slight bulge.
These things don't seem to be build to last, from what I've been reading.
Options:
-Break it down, sell the parts that are likely to still be good (wireless minipci card, memory, processor, heck - maybe even the front ports if you get longer cables/extensions), and maybe make around $200 that can be invested in a reliable machine.
-Or drop money into replacement parts. (but after what dj said about a second mobo going bad, I don't think it's worth investing more in this)
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: acer aspire one - its died!!!
I have a problem with my Acer Aspire 3100: This is what shows on the screen;
Phoenix Trustedcore (tm) NB
Copyright 1985 - 2005 Phoenix Technologies Ltd
All Right Reserved
System BIOS Version: v2.83
VGA BIOS Version: ATI UMA V008.0501.017.000.18675
CPUO = MOBILE AMD Sempron (tm) Processor 3500+
640K System RAM Passed
446M Extended RAM Passed
512KB L2 Cache
System BIOS Shadowed
Video BIOS shadowed
ATAI CD-ROM: Optiarc CD-RW CRX880A
Fixed Disk 0 : Hitachii HT S541680J9SA00
Mouse initialized
Error
0280: Previous boot incomplete - Default Configuration
Used
Can anyone help me please?
Damie
Posted on Apr 29, 2009
splintellz1
  • 37 Answers
SOURCE: Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Posted on Jul 03, 2009
  • 277 Answers
SOURCE: i have a acer aspire M3641 quad core desktop
paulstn62,
Your motherboard may not be fried, but the capacitors around your CPU may have popped,which can be repaired...
Posted on Sep 05, 2009
  • 615 Answers
SOURCE: need a new power supply for aspire x1200 desktop
If you in the USA you can pick one up from Fry's for less than $80.00 both... Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 29, 2009
Acer Aspire z5761 recovery disk wanted
You can contact Acer tech suppot and get the discs. It's cheap.
Oct 11, 2015 | Acer Aspire Z5761 23" All-in-one Computer...
Why does my acer aspire z5761 keep freezing and has horizontal lines across screen and constant bleep?
You probably somehow killed the screen. Did you drop it or bang it into something? You can try downloading and replacing the drivers, but I doubt that will help. Lines on the screen are usually a physical problem, not software related.
You may try a Windows Restore if your machine has that ability. Some do, depending on who you bought it from. Again, doubful it will help, but worth a shot.
Need more information on the bleep. When does it bleep? Constantly? When you touch the screen? Or when you boot it up? What kind of bleeps? One? Several? Long? Short? Both? Repeating sequence?
Jun 28, 2015 | Acer Computers & Internet
I have an Acer Aspire AM1641 U1521A desktop that will not boot up. No beeps, errors or monitor activity. Do I need a new hard drive, motherboard...?
Power Supply. Weak voltage power rail.
Has enough power to light LED lights, maybe spin fans, (Or spin a few times, and stop), but not enough power to turn the Processor on.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Depends on what Processor it is.
Acer Aspire M1641-U1521A?
Intel Pentium Dual Core E2180 (2.0GHz)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
Can use up to 65 Watts. (TDP)
The Power Supply used is a 250 Watt unit. Acer isn't known to use high quality power supply's. It's a generic low quality Power Supply.
[ However in all fairness to Acer, if the inside of the computer, AND the inside of the Power Supply, isn't cleaned out on a regular basis as needed, this can cause Power Supply failure also.
Use a can of compressed air for computers, with the plastic 'straw' attached. Hold onto the can with one hand, use the other hand to hold onto the straw, shoot air through the ventilation holes of the Power Supply's case. (Computer unplugged from power)
Come around to the back of the computer, use the air to clean the Power Supply's fan blades, center hub, and surrounding cage. (Shroud)
When the cooling components for the Power Supply, (Fan and Heatsinks used inside), become clogged with dust, dirt, etc., the cooling capacity drops tremendously.
The Power Supply overheats.
Heat = Wasted Energy
The Power Supply strains to keep up with the call for power, but eventually cannot, and fails.
Components inside the Power Supply fail ]
Replace the Power Supply.
Sep 28, 2010 | Acer Aspire M1641-U1521A PC Desktop
Acer desktop stopped working
whining is bad sound usually means one of your fans is dieing most common cause is cpu heatsing or power supply fan check those to out bye powering the case up with the side panel off see if the fans are spinning if you see any of the fans not working power off asap and replace the fan that is making the noise.
Jan 26, 2010 | Acer Aspire™ T180 PC Desktop
No power, no beep, no boot but the fan is working. its acer aspire L310 desktop...do I need a new motherboard?
yes...i guess so...
because if the MB is OK then it must at least boot as booting is from CMOS/BIOS which is part of the MB...if it's not coming on and nothing comes on screen....then ur MB is out...
the FAN is of the power supply unit..
Dec 21, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Booting problem
DEAR,
AS PER YOUR PROBLEM I THINK YOUR COMPUTER WORKING WITHOUT ELECTRIC EARTHING. PL FIRST COMPLETE EARTHING WITH ELECTRICIAN.
YOUR EARTHING IS NOT PROPERLY PL CHECK THAT:-- ELECTRIC SHOK ON PC BODY.
YOUR PROBLEM WITH POWER SUPPLY OR PROCESSOR,MOTHERBOARD.
PL FIRST CHECK POWER SUPPLY,SECOND CHECK YOUR PROCESSOR WITH ANOTHER PC MOTHERBOARD.
Feb 25, 2009 | Acer Aspire™ T180 PC Desktop
ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Jan 18, 2009 | Acer Aspire T135 PC Desktop
Acer aspire sudden death my acer aspire L100 can't boot, only the noise of the fan and the DVD player. nothing else can anyone help please ?
Dear sir
if u don't get eny display 1 you need to cleane RAM then it's still not working you need to chek power suply.. and chek yr cables is attached is right or not.
simple.. if u need more help please contact feel free.. thianks..
Dec 15, 2008 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
