Question about Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305. Problem receiving activities and courses
When uploading from my Garmin Forerunner 3o2, I nearly always have to synchronise a number of times in order to get the message "...successfully received from your device". I usually get "Problem receiving activities and courses".
  • Anonymous Feb 15, 2009
    Same problem. No solution yet ?
  • jeanieb7 Mar 24, 2009
    Same thing happens to me. Plug in 305 to computer and it starts the synch procedures then finishes with "your workout data was successfully received from your fitness device. There was a problem receiving the activities and courses"
    Often (more often that not) I have to reattach the device (ie unplug and plug in again) a few times to actually receive the workout data. The problem receiving the activities and courses happens every time.
This turned out to be corrupt data on my machine. I opened the Garmin traing center, backed up all the courses then deleted them inside the Training centre. I then received from device and all was okay.
Posted on Jul 31, 2010
  • EricSHansen Jun 28, 2011
    I had to delete my activities and my workouts and then it worked.
Here's what solved the problem for me: I previously had the Garmin cradle connected to a 4-port USB hub (splitter). When I re-connected the Garmin directly to the computer, the downloads worked fine.
Posted on Sep 19, 2009
Unplugged the watch, exited TC, plugged it into a different USB port and bang - it all came over fine. who'd have thunk it?
Posted on Nov 21, 2012
I have the exact same issue..did you find a fix yet?
Posted on Jun 20, 2009
  • 3 Answers
I received the same error for a first time today. My last workout (3 hours 24 minutes recorded at 1 second intervals) would not transfer to the training center but i could see it in the history in my 305 unit.
Updated the Garmin Training center software, rebooted, recoonected - no luck.
Called Garmin, spend 40 minutes waiting, then a lady walked me trhu updating the software on the GPS unit to the latest version. Still no luck following her directions after the update. However, quitting the Training Center, turn off the 305, then put it back in the cradle (while still off), and it synced just fine as it has always done before. I guess in my case, updating the unit software helped, even though I had only once verison behind the current...
Anyway, this is what did it for me:
(1) Update the Training Center (your PC software) to the latest version.
(2) Update your unit's software to the latest version.
(3) Quit everything you have running, turn off the 305, take it out of the cradle, re-connect, run Training Center if not running automatially, and transfer your date from the File menu...
Before doing all that, remember to back-up your data from the Training Center, just in case. File/Backup...
Posted on Jul 20, 2009
Garmin Forerunner 305 will not upload to Garmin connect, an error message says "object error"??
Try uninstalling and reinstalling the Garmin Communicator Plugin.
http://connect.garmin.com/help/start/usb
Also, you can call Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 04, 2011 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 "problem receiving activities"
I've had this problem. First -- and this sounds weird -- use a USB port on the back of your computer. Do NOT use a "secondary" type of USB port, such as an add-on hub, the ports on the front of a desktop machine, ports built into peripherals like a monitor, etc. Apparently, all USB ports are not created equal. Second, make sure you've the freshest Garmin Communicator plugin (which may entail a fresh download/install).
Apr 28, 2011 | Garmin Forerunner 305 GPS Receiver
Since the New Year, when I put my Garmin Forerunner 305 on the docking station to transfer my runs to my computer, everything works as it always did except I get this message-- "There was an error...
This problem has surfaced yesterday for me after about 18 months of worry-free transfer. Reading the posts seems to have something to do with the cradle. I just took it out and re-seated it and pressed hard. something to do with connection because it has been charging. of course just before I had deleted the workout i had added on the TC. perhaps that helped as well - not sure.
Jan 15, 2011 | Garmin Forerunner 305 GPS Receiver
I have a Garmin Forerunner 305. When I connected it to my PC It started to charge right away and then made an attempt to upload the data. The upload failed, although indicated it was successful on the...
the Gps should be on when you connect to the computer even if the battery is not good
it could be that it overloaded and the fuse burned
I fix the GPS
i am in New York
ecrdn@yahoo.com
Sep 17, 2010 | Garmin Forerunner 305 GPS Receiver
My Garmin 305 will not turn on. Battery will not charge nor indicate anything on screen. Will a replacement battery correct this problem? Where can I get it repaired near zip #23502?
Probably it's not linked to battery. Try resetting device (see on garmin support how to do holding mode&reset buttons).
Myself I can restart it if applying this, but it restarts only once, always same procedure needed to make it start.
Aug 22, 2010 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 GPS Receiver: How can I change my Garmin 305 from miles to kilom...
Page 48 of your manual, Changing Units of Measure. Settings > General > Units
May 17, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin 305 charges but wont upload to PC or MAC - have changed the cable but still not upload last training sessions
The Garmin fitness units are unreliable. I don't know the answer but the first place I'd look is in the Motion Based Forum.
Nov 04, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin 305 stops uploading data
Try maybe a different computer and see if it works. If it doesn't then something is wrong with your item. Clearing the history won't help.
Aug 21, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
5,783 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
