Question about Monte Carlo (5LCR52MW) Fan
I have a wireless control for my fan/light that's mounted on the wall and it's not working. I've changed the battery,was able to turn light on but that's all. won't work the fan
3 Suggested Answers
  • 579 Answers
SOURCE: Light on fan.
Most likely, the dimmer control has failed and needs replacing. Would be good to check its output voltage first.
Posted on Dec 31, 2007
  • 569 Answers
SOURCE: remote control wall unit does not turn on Monte
Are the manual switches on the fan in the 'on' position?
Select the maximum fan speed on the remote and then operate the manual switch on the fan. Set that to the highest speed then control it with the remote.
Same theory applies to the light.
If this is not the problem then the remote receiver on the fan is probably faulty.
Posted on Feb 28, 2010
"Ball Ceiling Fan" - hardwired wall switch only turns on or off, no speed control or light control, stuck on "high" and light "on" when switch is in "on" position.
The most likely cause (and the one I've always encountered) is the switch/controller nit wears out from electrical arcing that burns the contacts or temperature kills electronics on "soft" speed controllers
Mar 03, 2013 | Modern Fan company ball ceiling fan
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
Changed batteries in remote fan still doesnt work hampton bay model uc7083t
If you're gettig a red light whenever you press a button on the handle remote, That means the hand held is working. There are also batteries in the receiver , inside the fan's cowling. They need to be changed too. Also, be sure the wall switch is ON. The remote has no control, if the wall switch is OFF.
Hope this helps and thanks for choosing FixYa.
Jul 28, 2011 | Hampton Bay Heating & Cooling
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Lights are on all the time, fan doesnt work, remote does not work
I have changed the remotes on 5 Hunter fans in the last 3 months. They have a problem with how some of them mount, that makes them drop down and vibrate loose. If you do not have a wall switch for it, you may want to go to pull chains, or just replace the remote. It is NOT the controller you hold in your hand, but the part in the fan. (never the easy way right?) The remote is not hard to change, but you DO have to let the fan hang from the holder on the ceiling bracket, It gets too heavy to hold while you change the remote.
All but one of the remotes I have changed, came from a mass market type of builder/handyman store, and they have just replaced the part at no charge.
Dec 21, 2008 | Hunter 52" Ceiling Fan With Light And...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Monte Carlo (5LCR52MW) Fan Logo
42 people viewed this question
Top Monte Carlo Dryers Experts
Craig Butler
Craig Butler
Rani wadia
Rani wadia
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
