Question about Onkyo MC35Tech CD Shelf System
Power problem in MC35Tech
I screwed up my amp by hooking it upto 240 V power line without a transformer. I've been using this for almost 4 years with transforment but when I was shifting I made this mistake? how easy/expensive it would be to get this fixed?
Thanks a lot in advance.
  • vijayan_othe Jan 13, 2009
    Thanks a lot for helping out. I'm planning to take the amp to the dealer to get it fixed, from your response I hope it would be fixed with less expense to me.
    Thanks a lot again.
  • 2,071 Answers
Don't worry it has protection equiped that will not damaged your unit a fuse .Open the unit and look for the transformer inside near there where the fused is located. Free free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Posted on Jan 12, 2009
POWER VOLTAGE
No. To work with 220V~240v; the device need a step down transformer to be connected in between line and device. The transformer [voltage converter] should be used, otherwise; the unit will get damaged. The step down transformer adaptors can be bought locally. http://electronicshelponline.blogspot.com/
Oct 30, 2014 | JVC GR-D70EK Mini DV Digital Camcorder
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a...
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
I replaced my thermostat last night without
check for 24 volts ac at R & C terminals at the t-stat. Your transformer will have 4 wires hooked up to it. Two on one side and two on the other. Two of them will read either 120v or 240 v ac depending on whether you have a 120 or 240 v voltage. The other side should read 24 volts. If you are not reading 24 volts, then you have burnt the transformer and will need to replace it. If you are reading 24 volts, check to see if there a low voltage fuse located on the control circuit board or somewhere between the transformer and "R" terminal.
Here's a picture of a typical low voltage transformer found in an A/C system:
If you replace the transformer, add a 5 amp fuse on one of the 24 volt leads......this will save you from having to replace another transformer in the event of future "short" in the low voltage circuit.
Contact me with any questions or concerns.
I hope you find this to be very helpful to you moving forward,
Please leave a rating. :-)f0b3aee.jpg
May 09, 2010 | Heating & Cooling
House has 4 tv points only one in use at any time tv arial is high gain and has a booster and fitted with 240 - 12 v 100 ma amp on incoming line vhf picture has wavy lines from left corner to right this...
If the power transformer to the amp is close to the coax you will get these wavy lines. The addition of a second load canjcels out the waves which is like a harminc frequency. Try plugging the transformer a little further away by using an extension powerboard to see if that helps you
Thanks for using FIXYA
Oct 11, 2009 | Televison & Video
Buzz in amplifier power transformer. The amp is a Marantz Model 240. It functions perfectly well, and there's no noise from it in the speakers, but the transformer buzzes whenever the unit is plugged in...
All transformers buzz though you cannot hear it normally. The big transformers on power lines like to buzz for all to hear. When a transformer in a stereo amp gets old and deteriorates or gets hot and  expands the coils, melts the coil varnish and epoxy coatings then rattles at 60 times per second.    You can ignore it or change the transformer. There are too many layers of windings to try to stick anything in there.  Disconnecting a transformer results in inductive kickback -that's not money. It's a big, whopping electrical gotcha! Be careful! Good luck, Steve Medley
Nov 09, 2008 | Marantz Audio Players & Recorders
ONKYO MC35TECH aka R-805X
Hi if you need a replacement plug for the system then you can buy them from any electrical store but if you want a transformer or anything product specific then you can contact Onkyo USA sevice centre on 201-785-2600.
Here is the Onkyo website where the number is from
. http://www.onkyousa.com/customer_support.cfm
Or for European service centres go here: http://www.eu.onkyo.com/indices/index_com_en_2008_5946251.html
Oct 29, 2008 | Onkyo MC35Tech CD Shelf System
'phones engaged' no sound
Well,
My onkyo receiver was keep displaying "Phones Engaged" and no sound.
All I did was plugged in a phones plug and remove it and for the last 2 weeks there is no problem.
I just happened to have a phone plug (without the actual headphone or wires) and that seems to fix the problem.
Hope it will work you all of you as well.
Good luck.
May 26, 2008 | Onkyo TX-SR502 Receiver
HOW DO U KNOW THE CAPACITY OF AN COMPUTER SMPS (unbranded)
Maximum output of any smps is not based solely on the type of power switching transistors used. One of the parameters which will be crucial is the Ic (Max collector current rating). But this by itself isn't the lone determining factor either.
Other design factors which will come into play are the switching transformer, its size and windings. A smaller transformer and smaller wire gauge windings will generally mean lower max power output.
Max power output measurements probably require a set of load resistors, volt and amp meters, monitoring the 3.3, 5, 12 volt lines.
I'm not an engineer, but have had numerous computer power supplies apart, repairing some, junking some. Quality of construction or lack thereof is generally obvious. PC Power and Cooling probably builds high quality units. There are plenty of cheap, low cost power supplies which frequently die after a year or two, sometimes taking a motherboard down with it.
Dec 21, 2007 | Compaq Refurbished 280WATT POWER SUPPLY...
Onkyo MC35Tech CD Shelf System Logo
135 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
