Question about Surefire A2 Aviator Flashlight
Aviator 2 surefire new batteries and bulb unable to get more than a very dim red leds
2 Suggested Answers
  • 38 Answers
SOURCE: Have a Surefire Executive Elite
If you can access the "guts" of the device. Try and see if there is an electrical malfunction such as frayed wire or moisture on the circuits. It sounds like an electrical short is causing the bulb to work harder that it needs to causing its life to be drastically shortened. If its an investment, I would go ahead and set up service for the device (or if you have the capabilities and know-how to repair it yourself it might be easier). Remember though any attempt to repair an item yourself might void the warranty.
I did a little research and found that all products from the manufacturer are under lifetime warranty as long as they are owned by the original owner. Go ahead and send it in for an easy hastel free repair.
I am not sure if you are in the us again but I have here two different numbers to set up service
Toll Free:
Outside US: 800-828-8809
714-545-9444
Posted on Oct 16, 2010
Must I replace its 100 watt Sylvania incandescent bulb with another incandescent? What about an equivalent CFL or LED bulb?
Both will work fine as long as the light isn't on a dimmer. You can't dim CFL bulbs.
If you do have a dimmer, you can dim LED bulbs as long is you buy dimmable LED bulbs.
Which LED bulbs are best for built in dimmers CNET
Dec 29, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
Is there a reason not to use LED lights in my Casablanca metropolitan fans with intellitouch controls fans
I think the fan should be fine. If the fan is set to have a dimming option and the bulbs you use are dimming bulbs, I don't see the problem. They may be from different manufacturers but they should cause damage to each other. LEDS shouldn't be a problem.
Elisa Jed ' http://fancfans.com/fans/huggers
Apr 22, 2014 | Casablanca Fan Metropolitan 6445T
Have a Surefire Executive Elite E1e. I purchased it new in 2007 prior to deploying to Afghanistan. After a period of 7 months, the bulb burned out. I ordered a new bulb and replaced the old bulb. It lasted...
Toll Free:
714-545-9444
Oct 16, 2010 | Surefire E1E "Executive Elite" Flashlight
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
My son dropped the flashlight acouple times and now it wont work
Either the bulb is burn or just faulty or the switch is bad.
Jul 16, 2010 | Surefire 6P BK 6P Original Personal...
White light is not working / changed the bulb and it still inop
It could be a bad contact, you can contact Surefire at www.surefire.com at speak to Tech Support. They are excellent at honoring their Warranty so they will most likely repair it or replace it at no charge.
Jun 16, 2010 | Surefire A2 Aviator Flashlight
Does not come on at all. Batteries good, ON button barely depresses, have unscrewed back cap and front lamp cap with no fix. Why is button so stift, is there a way to test the LED?
It sounds like your switch is bad. Contact Surefire at www.surefire.com and talk to Tech Support, they can better help you and they do have a excellent Warranty and will replace it if it cannot be fixed.
Jun 13, 2010 | Surefire 6P
I replaced the battery in my surefire E1B light. Nows it will not come on.
You can call up Surefire www.surefire.com and talk to Tech Support, they are real good about backing up their product.
HEADQUARTERS
SureFire, LLC
18300 Mount Baldy Circle
Fountain Valley, CA 92708
Toll Free: 800-828-8809
Outside the US: 714-545-9444
Fax: 714-545-9537
Guarantee/Warranty
May 22, 2010 | Surefire E1B Backup LED Flashlight
Surefire A2 Aviator Flashlight Logo
32 people viewed this question
Top Surefire Camping, Backpacking & Hiking Experts
Vernon Taylor
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you a Surefire Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
