Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
Broke mpthe mirror in my WS-55313 Mitsubishi projection tv while moving it. Just wondering how much it will cost to get a new one. Is less than 100 dollars reasonable? We dropped it while moving it and the mirror broke. We turned it on and the middle of the screen was dark and going out towards the edges it was red and green, then it was normal colored. I am assuming all that needs to be replaced is the mirror
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
A few notes:
First if the mirror which hangs at a angle facing the screens comes apart it can come forward and smash the inner screen.
The best way to proceed is remove the entire front screen frame:
remove speaker grill on front under the screen (if cloth it should pull out in one piece (a few are two piece).
With it removed look under the bottom front edge of the screen unit--left to right there are several identical screws and you have to remove those.
If the front controls (vary by cabinet style) are in the bottom front of the screen unit there will be wires from them hanging down--should be an inspection plate dead center behind where the grill was.
follow the wires from the front control board down with the inspection plate removed and locate the one or two inline plugs and disconnect them (they pull apart and are marked)
With the screws at bottom of screen frame removed and the keyboard free pull out the frame from bottom and slid up about 4-6 inches the entire frame with the screens still in it.
Do not when you do this twist the frame as you can pop the screens right out.
Set the frame and screens to one side making sure not against the screens and avoid touching the inside screen inside the frame.
You should now be able to see the mirror clearly, be careful if cracked as when you release the screws that hold it in it may come apart and use gloves---broken mirrors are very sharp.
Mirror should if you see the plastic and wood slots for it not be too hard to remove and replace. Vac out any small glass as light from the set inside can reflect onto the new mirror or even the inside of the inner screen and be seen in the picture.
You almost certainly are going to have to get the mirror from Mitsubishi---price it with shipping but since its a 55 inch mirror almost any mitsubishi mirror that size will work perfectly--some shops save them....hint.
Most of those mirrors were at or over 100 dollars and a few sites on the net sell replacements in case Mitsubishi is too high.
Hope this helps and let me know if need advice.
Posted on Dec 06, 2012
SOURCE: Distorted picture and multi-color words
You need to resolder the convergence chips. This is a very common issue with this line of TVs.
Hometheaterspot.com's Mitsubishi forum has detailed posts on how to fix this. Just serach for "55809 convergence" and you should find the info you need.
Posted on Dec 20, 2007
  • 1153 Answers
SOURCE: mitsubishi ws-65905 color tube needed
What is going on with green? I may can help
Posted on Dec 26, 2007
  • 41 Answers
SOURCE: deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
Posted on Dec 17, 2008
SOURCE: Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Posted on Feb 05, 2009
SD Tech
  • 14553 Answers
SOURCE: Image problem with WS-65809 65" Mitsubishi Projection TV
WS-65809?, if convergence is skewed and comes and goes, uses two of the STK-392-570 CONVERGENCE IC chips.
I have seen a lot of the Mitsubishi sets that use these two chips where the convergence jumps in and out. You need to replace both chips and adjust the set.
You can buy a pair of the chips on EBAY for less than 13 dollars plus shipping.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THE SETS THAT USE THESE TWO CHIPS.
If you or someone you know can do the repair you can save the set and a lot of money--most shops are going to get at least 300 for this kind of repair--I know as I have done hundreds of them here.
The instructions tell you everything you will need and how to do the repair. I have helped many people here do this based on my instructions.
If you want the instructions let me know and I will either post them here or send them to you.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 30, 2009
My 55313 power light dose not come on
The SMPS section is not oscillating. Your TV need a through checkup. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 24, 2013 | Mitsubishi WS-55313 55" Rear Projection...
I need a new remote for a WS-55313
If the tv was moved it may have a loose cable...you can get remotes for way less than that.
Mar 18, 2012 | Mitsubishi Televison & Video
Mitsubishi ws-55313 vertical hold problem with tv
This set does not have a vertical hold control etc---try to explain what the set is doing or not doing so I or another expert can help you.
SD TECH
May 18, 2011 | Mitsubishi WS-55313 55" Rear Projection...
Hi, i need a circuit board for a ws-55313, tv no is js-5531378010478
Encompass Parts Distribution has List of Parts/Prices and Free Service Manual that you can print out online 1-800-638-3328
Model# WS-55313 Your Model# will be printed on the back of the TV.
Nov 09, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I have a Mitsubishi WS-55313 55 in. Rear Projection HDTV. My problem is, the picture suddenly goes to a black screen, while the audio remains. When I turn the TV off, and then back on, I may or may not get...
your dose not use lamp, it is a crt driven TV . One of com problems for that model was loose connection on one of the yokes. When that normaly happens , there is a sudden flash and screen gose dark and sometimes it can flash back if not you get red light blinks. If you you know where the yokes are at check little small board . A small mirror will come in handy, access from front of TV. adios ... john
Mar 31, 2010 | Mitsubishi WS-55313 55" Rear Projection...
Jan 31, 2009 | Mitsubishi WS-55513 55" Rear Projection...
HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Dec 21, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Deflect power supply
Nov 10, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
