Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9202 60''
After my projection tv is on for about 3 mins...the colors starts to shift and bow at the bottom yellow and at top blue duplicate picture effect..what do u think i should do
  • 4,234 Answers
This is a convergence problem that is being effected by heat. If you can solder, you should be able to resolve this yourself. Please be aware that there are potentially dangerous high voltages present inside the set even when unplugged.
Look for the large black ICs attached to a heatsink that will be marked STKxxx. These are the convergence ICs. Try resoldering the pins on these ICs and report the results. If the resoldering does not resolve the problem, the ICs may need to be replaced.
Keep us posted,
Posted on Jan 12, 2009
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a bowed picture on the top and bottom of the screen of my philips rear projection tv
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix using this link on Fixya
Jul 19, 2009 | Toshiba 42H81 42" Rear Projection...
Tv colors and bows
sounds like convergence ICs but I dont have any info available on the VS55601 model number.
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Bows on sides
Try degausing the set with the system software. if this doesnt fix it you will have to degause the set with a professional tool.
Tv Colors are bad
You have a convervence problem. You will need to replace both convergene chips and possibly the resistors. You can get more information and a repair kit with instructions from
Jan 09, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Color of the picture
Hi! henori,
This set is out of convergence. Go to your menu button on your remote, press it, then
find convergence and follow the directions for adjusting the convergence.
Oct 15, 2007 | Philips 55PW9363 55" Rear Projection...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good me at
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
