Question about Dell Inspiron 1525 Notebook
I cant find my touchpad icon
I accidently uinstalled my touchpad driver synaptics driver on my dell inspiron 1470 laptop
    Guru:
  • 571 Answers
You can do a system restore in your computer to revert it back to the known good condition.
go to start or pearl > Accessories > System tools > system restore. Select the date when the synaptics driver was still in your computer.
I hope this helps.
Posted on Dec 06, 2012
vincent721
  • 240 Answers
SOURCE: Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Posted on Apr 03, 2009
peeface
  • 180 Answers
SOURCE: dell inspiron1501 touch pad sensitivity problem
you are going to have to go into the control panel and to the mouse properties. in there you will be able to put the icon back in the taskbar. i dont know why it changed itself though. on my dell a couple times i had to reinstall the mouse drivers for some reason. i just went to dell.com and got them there. hope this helps
Posted on Apr 22, 2009
  • 326 Answers
SOURCE: SM Bus controller drivers for dell inspiron 6400 laptop
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=INSPIRONI6400/E1505
try those drivers and let me know if they dont work
Posted on May 15, 2009
  • 3940 Answers
SOURCE: i formatted my dell inspiron b120 model laptop i need lan driver
Here is a link to the Network Driver:
http://dsn.us.dell.com/DSNCR/DSNGateway?target=GetDocument&objectID=0E2392E739334481872AE06262A4FC10&languageCode=EN&regionGuid=DD4C7CB26E136815E030A68F27285B52&open=1
Posted on Jun 06, 2009
SOURCE: TOUCHPAD DRIVERS DELL INSPIRON 5100 WINDOWS XP
imy dell inspiron 5100 touch pad is not workign please help me
Posted on Nov 30, 2009
How to adjust touchpad sensitivity on dell inspiron 1525
Open Control Panel, Mouse, I don't know your OS?, OR, in the Tray Notification Area, open the Touchpad software Icon, maybe synaptics touchpad, settings, sensitivity Take a look at the Dell forum: http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=cmu&k=adjust+touchpad+sensitivity&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False
Feb 08, 2013 | Computers & Internet
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
The touchpad's scroll isn't working i know i can sound so dumb but i can't find the driver, can u please help me?
Dell Inspiron 6400 is using Synaptics Touchpad. Please make sure to remove your existing driver and re-install it with the new one. You can download the driver from their official website here.
Jan 13, 2011 | Dell Inspiron 6400 Notebook
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
Why does Dell Touchpad settings disappear after rebooting when running Vista?
Because vista is not very driver friendly...try re-downloading it and putting it on your desktop to see if it's deleting the file, or filing it in some location that makes sense only to vista...So, go back to Dell and download the Synaptic driver for your PC thats vista compatable. I haven't been to dell in eons but they use to offer two different drivers, you want the Synaptic driver. That should put a icon down by the clock to give you quick access to the settings..
Jul 05, 2010 | Dell Inspiron Notebook
Inspiron Keyboard Jumps Around
Install the latest touchpad driver from support.dell.com
There is a setting in the touchpad tab of the mouse driver. Either Enable PalmCheck or Disable touchpad when typing (Depends on Synaptics or Alps drive I believe)
With palmcheck enabled, the touchpad is disabled when typing
Jan 24, 2010 | Dell Inspiron 1420 Notebook
How do you enable a touch pad on a dell computer. The feature disappeared after my laptop was reloaded due to a virus
Two different ways to do it...
1. Use your function keys... Combination of the Fn key (next to the Alt Key) and one of your "F" keys, look on your F-Keys you will see icons.. Look for the Touchpad Icon
Then Press Fn and Corresponding F Key at the same time to Enable/Disable Touchpad...
OR
Go to Dell.com scroll to bottom of website's home page and look for: SUPPORT AND DRIVERS.... Click on the Text and It Will Then Ask You To CHoose ... LAPTOP, or Desktop, or Tablet etc.... You Choose LAPTOP..... THen Choose THe Model from the list, then choose the model number from the list and it will then take you to Your Laptops Drivers Page... Scroll Down and Find Your Touchpad Driver and Redownload it and install it....
Nov 15, 2009 | Dell F3534 Touchpad
The scroll function doesn't work
Download the latest driver for the synaptics touchpad for your laptop from support.dell.com. Most likely the driver for your touchpad was not fully installed or may have been damaged. Install that and you could get the scroll on your touchpad back.
May 09, 2009 | Dell Inspiron E1505 Notebook
Dell touchpad problem
Try to reinstall the touchpad driver.
Get it from this link.
Dec 09, 2008 | Dell F3534 Touchpad
Dell Inspiron 1525 Notebook Logo
27 people viewed this question
Alun Cox
