Question about Verge DFP-200 MP3 Player
Broken battery door
I have tried to locate somewhere to find a battery door and end for my player. It was droped and it still works fine I just have to tape up the end so the battery will make connection. Does anyone know how to locate the parts? I have seen the manafacture has some bad reviews on there customer suport.
  • 8,596 Answers
They are WAY out of business - parts no longer available
Posted on Jul 06, 2008
SOURCE:
The light in the fridge side has stopped working bulbs are ok
Might be a stuck switch. Somewhere around the edge of door is a small pressure switch that pops out when door is open and gets pushed back in when door is closed. This can stick or even break.
Check the bulb shoe connectors aren't corroded both on bulb and in socket.
Switch off device first !! then get to bulb and scrape connections with screwdriver tip, very lightly. Switch off first !! (just saying it again).
Test the bulb too with a 9v battery. they may look fine but until you actually know ......
Aug 10, 2016 | Refrigerators
Camera was droped now it does turn on and the lens
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 01, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
The doorpannel speaker will not work on one but
If you have access to the rear of radio, try reversing the channels, to see if the speaker works, and if it does, then you know the wiring to door speaker is ok, if it doesnt, then you know that the wiring is broken somewhere along the route. If you have access to the cable itself only, try using a AA battery, attach the cables to both ends of the battery, and if it makes a noise, then wiring is ok.
Nov 16, 2009 | 1994 Nissan Altima
Same problem
How long have you had the camera? If it's less than a year old, then it's under manufacturer's warranty and they need to take it back because there was no customer abuse involved to find it broken...
If it's more than a year old and you have no other warranties on it.. then I'm sorry to say that you might just need to try to fasten something yourself... keep in mind that the only function of that door is to hold the batteries in and to conduct electricity between the batteries... so if you put something there that is also conductive.. then it should be able to work fine.
Just be careful... electricity is sketchy to work with
Sep 10, 2009 | Kodak EasyShare C315 Digital Camera
Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Crosley CR248 Turntable
My daughter had the black and silver mp3 player and on the screen there is only emerson. no matter what button i touch it only stays on this screen. is it broken should i trash it and get her another one...
idk but i would go get another one and it worked fine till i droped it and the touch screen cracked out of site and you have to downlaod the software
Apr 23, 2009 | Audio Players & Recorders
MP3 player won't turn on
mine usually turns on the next day
Aug 16, 2008 | RCA OPAL M4001 MP3 Player
Hi I have a sharp gx10i, the camera wont work just comes up with loading and then stops, what can I do to get it to work, use to work fine? Thankyou
did you drop it cause this sounds like its been droped
when you droped it the circuitry became jared and broken you need to replace or repair
May 20, 2008 | Sharp Cell Phones
Battery wont charge.
Unfortunately, Mintek seems to have gone out of business, so there is no way to purchase replacement parts without finding them online somewhere.
The problem could be caused by one of three things:
  1. The battery is dead and cannot be recharged
  2. One of the battery connections is broken in some way
  3. The cord is bad and will not provide power
If the battery is dead, you're stuck with keeping it plugged in or trying to find a battery online. If one of the battery connections is bad, the only way to test it is with a new battery and you're back to finding one online. If the cord is bad, it wouldn't provide power at all, so it sounds like both of your cords are fine.
May 10, 2008 | Mintek MDP-1760 Portable DVD Player
Verge DFP-200 MP3 Player Logo
57 people viewed this question
Top Verge Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Verge Audio Player and Recorder Expert? Answer questions, earn points and help others
