Question about Sony VPL-CS7 Multimedia Projector
Please replace the lamp
My Projector is Sony VPL-CS7. when power on, it display message " please replace the lamp " . I replaced a new lamp but when it start up it still display the same message. Pls, help me about this problem. I dont want to see this message.
  • Anonymous Mar 26, 2014
    problem started after replacing lamp
    President:
  • 2,559 Answers
On your remote,push these 4 buttons in this order.
RESET < > ENTER
Posted on Jan 12, 2009
  • jmmiller369 Apr 08, 2011
    cannot seem to reset the lamp hours????
My sony VPL-CS7 projector lamp goes of very minutes
1,if the lamp can be lit for 1minute,so the lamp is ok
it seems that the lamp ballast or mother board is defective.pls check them
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 03, 2014 | Sony VPL-CS7 Multimedia Projector
Can only view image in a very dark room.
If you need it you can get the user manual on this link; http://esupport.sony.com/perl/model-documents.pl?mdl=VPLCS7 check page 29 - brightness setting adjustment just to be sure this is not the problem. check page 36 - lamp mode - try high if not already set on it. Check page 42 - cleaning the filter - this can stop the projector functioning properly, but i don't think it's the problem in this case If the image is being projected exactly as normal, apart from the brightness, then the problem is most likely a failing bulb, despite the low hour count. Just possibly (but unlikely)there is a power supply problem that is not feeding enough voltage to the lamp, only way to tell for sure would be to either get a meter on the lamp terminals, which looks practically impossible with the lamp in place, (possibly will give a reading without the lamp, but the terminals may be disconnected from the power when the lamp is removed), or replace the lamp. Are there any flashing lights or error messages at all, does the projector seem hotter than usual, is the fan running as normal? could you actually see any error messages on the projected image if they were there? try really hard to read them if you think there could be something there. Try a different input source, unlikely problem but possible. Especially in smoky environments the lens can get quite a thick layer of grime on the outside - easily cleaned off gently with some vinegar and soft paper towel/soft cloth. This made enough difference on a similar one in a bar near me to give them 3 months more with the same bulb. Worth a try. If you need to source a bulb you need Sony LMP-E180 there appear to be no cheaper substitutes, you can get one direct from sony uk on this link; http://www.sony.co.uk/view/ShowArticle.action?articlesection=1&article=1158155174490&site=odw_en_GB These lamps are often cheaper from the US even with postage, if you can find a dealer who will send you one, check this link for some ideas; http://www1.epinions.com/t-sony-lmpe180 I got a lamp for a similar sony projector sent to spain a few months ago, saving about $280!!! - I'll keep trying to find the details of the company I used, no luck at the minute. Hope this helps, post back if you have any more info :)
Jun 30, 2007 | Sony VPL-CS7 VPL-CS7 MMPROJ XGA 1800LUMEN...
Someone from my work has written instructions to connect the sony data projector vpl-cs7 to our laptop. it says to insert the dvd. I do not have the dvd so am keen to download it but i don't know what...
you shouldnt need a dvd to install the projector all you need to do is enable the external monitor interface on your laptop. User manual can be found here
http://www.aboutprojectors.com/pdf/sony-vpl-cs7-manual.pdf
May 30, 2011 | Sony VPL-CS7 Multimedia Projector
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
Sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 19, 2009 | Sony VPL-HS20 Multimedia Projector
Lamp/cover light flashes orange
could be need new lamp
very expensive!!
how old is the tv?
is this the first lamp?
usually get 10000 hours use out of one lamp
Jun 01, 2009 | Televison & Video
Sony VPL-ES3
What documents you need for VPL-ES3, let me know please.
Have you replaced Lamp? give details of projector problem to find out solutons.
Sep 12, 2008 | Sony LMP-H150 Projector Lamp Projector...
Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Lamp Cover will not close fully
Hi there
Your lamp is not properly inserted.
The lamp door should close easily if your lamp is in correct.
If teh lamp door is not closed properly then the mashine will keep on shutting down.
Dec 13, 2007 | Sony VPL-CS7 Multimedia Projector
Sony VPL-CS7 Multimedia Projector Logo
621 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
