Question about Toshiba Satellite A105 Notebook
My Toshiba A105 has a black screen just as if it were't on. What do i do?
  • rltarrant197 Jan 12, 2009
    That didnt work?
  • anartey Feb 02, 2009
    I have A105-s4034 . I left it on over night to scan for virus, accidentally i covered the fan ventilation. when i got up in te morning the screen has gone blank, i have connected it a monitor but nothing works, i have tested the memories they are OK, I have thought it was the Processor I have changed IT, the problem is still the same. When you start it the power lamp comes on, and that's all.I need help!!!!!!!!!!!!!!!!!!!
You should take the battery off and replug it and start again.I think it will work
Posted on Jan 12, 2009
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
Toshiba A105-S4074 laptop's monitor has no backlight
Use the VGA port to connect an external monitor, this will get you up and running temporarily until you can fix the screen, it sounds like you have a faulty inverter.
Apr 06, 2010 | Toshiba Satellite A105-S4074 Notebook
Black Screen on Toshiba Satellite A105 S1014
Blown or damaged graphics chip on motherboard, would take to specialist repair shop
Feb 09, 2010 | Computers & Internet
Black screen, will not load up?
Is the battery charged? Might be a defective charger.
Jul 18, 2009 | Toshiba A105-S4054 Notebook
Toshiba Satellite a105 s4004
Here, I found this:
Toshiba Satellite A105. How to remove and replace laptop FL inverter and LCD screen.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
Jun 23, 2009 | Toshiba Satellite A105 Notebook
Toshiba a105 screen goes black then stops booting up when startng
try access the safe mode.. then remove the some virus or.. if you installed same latest program remove it then start again...
it you dont installed any program check the control pannel,, add and remove program remove all programe not neccesary...
Jun 08, 2009 | Toshiba Satellite A105 Notebook
Dropped Toshiba satellite a105 laptop, screen black
If you pull off the top part where the speakers are above the key board your monitor might be unplugged. i had the same problem with one
Mar 09, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite a105 screen problem
You need a new lcd, The connectors are bad...
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Black screen
use the same key combination once again it will give you your display back...
Dec 02, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite A105-S361
the inverter maybe going bad. go to ebay get a cheap toshiba satellite a105 lcd inverter.bam the problem fix oh you would need a screw drivercause this is a diy project no need tosend it out link me if anything bakerandre2000@yahoo.com
Apr 14, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite A105 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
