Question about Sony WEGA KDE-42XBR950 42 in. HDTV Plasma Television
How can i connect apple tv to SONY KDE 42 XBR. It does not have a HDMI Port
I pirchased a HDMI to DVI adapter cable. Does it transmit Audio, or should I use a seperate optical audio cable. If so, the SONY XBR does not have a Optical audio IN jack
3 Suggested Answers
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
  • 87 Answers
SOURCE: No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Posted on Apr 20, 2009
I have a Sony blue ray player connected to my rca TV through a HDMI cable to a HDMI to dvi adapter I get picture but no sound. How do I get the sound to work?
sir DVI is only support for video you can get video through DVI not sound if your tv have no hdmi port then please purchase adapter which is called HDMI to av converter
thanks
Sep 21, 2017 | Sony Televison & Video
I recently bough a used 40in sony trinitron xbr. i have the DVI to HDMI cable but wether its my laptop or xbox the sound wont come through the tv at all. any suggestions?
Check the audio cable it might not been connected securely.
Could also be missing.
Even with the HDMI you may still needs it ( DVI is for video only).
DVI means Digital Video Interface.
Sep 26, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
How do I connect my iMac 27" i7
You can buy an optional cable that you can plug into the mini-DVI or mini-displayport port at the back of your iMac.see example picture on: http://www.ecoustics.com/electronics/products/new/570842.jpgFirst you need to be sure to know exact if you have a mini-DVI or mini-displayport. The connectors are different and depend on how old your iMac is. Than you can buy the connector that fits your Mac. The you only need to check the connections on your TV. HDMI or DVI will give the best image quality. VGA is older and will result in a lower image quality. Last, you need to buy a cable between the adapter and your TV.
Jun 12, 2012 | Apple iMac Z0GF0005F Desktop
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
How do you connect a mac to an HDMI device and can you get sound to the tv ?
Hey, you would need a Mini display to HDMI cable and unfortunately the sound cannot be ported through the mini display port.
Mar 14, 2011 | Apple Customized 15" MacBook Pro Laptop...
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
My tv does not have an hdmi port. I have a device I'd like to import (Apple TV) I'd like to connect. It has an hdmi input for connection to the TV. Is there something I can do to be able to connect to a...
There are adaptors available to convert HDMI signal to other standards. You will lose quality in picture and sound but you can get HDMI to RCA converter. If your TV has a DVI is still a digital input so will yield better quality.
Jan 14, 2018 | Pioneer PDP-425CMX 42 in. Plasma...
No sound when hooking up DVi to HDMI...
This is normal, when you go from HDMI to DVI, the sound does not get transmitted. You need a separate cable to go from audio output on the computer to Audio input to the TV. There are speaker (headphone on laptop) jack to RCA audio cables, you could also go with digital audio or even optical out if your computer and TV both have the input and outputs.
Oct 05, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
Sony WEGA KDE-42XBR950 42 in. HDTV Plasma Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
