Question about Amana Refrigerators
TD23 approx 25 yrs old Top mount freezer. need part # for FC door gasket
  • 87 Answers
SOURCE: Freezer door misalignment on ARB8057CSL
Before adjusting hinges you need to take a good look across the door from the side to make sure the door is not warped rather than the hinge misaligned. Cannot give much info on hinges but most do not give much adjustment and most can be accessed it is possible that one of the fixings is loose. The other possibility is that the seal is preventing the door from closing, although it does sound as though it is the top hinge not pulled towards the cabinet properly. Sorry to be vague. Hope this is of some help.
Posted on Sep 12, 2007
SOURCE: Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Posted on Oct 11, 2008
  • 400 Answers
SOURCE: Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Posted on Mar 06, 2009
  • 219 Answers
SOURCE: ice forming on freezer back wall of 6 year old top
u have a defrost problem unplug for 4 or 5 hrs with door open will work like new till u can get a tech out to replace parts
Posted on Mar 19, 2009
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
I have an Enduro Waterco T500 sand filter approx 6 yrs old how do I get the multi valve off the Pod?
If its a top mount then there will be a clamp held together with some type of nut and bolt, compressed on with a giant plastic nut and gasket, or screwed on.
Dec 28, 2015 | Pool & Spa
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Feb 12, 2015 | Frigidaire Freezers
Sub Zero drawer freezer is filling up with ice crystals. Looks like from the ice machine. Help!
When we had ice crystals in the freezer it was because liner in the top of the freezer where the water is to drain to the back of the freezer and out the drain tube was deteriorated. We lived with it for about a year.
Contact sub zero for information.
Ours was 23 yrs old
Jun 23, 2014 | APW Wyott SubZero Refrigerator Freezer...
It's a Viking freezer, not refrigerator. I know it is an older model but I don't know the model number. Ice forms on the coils on top of the freezer and the temperature inside the unit rises to...
VCBB363SS is a refigerator on top with a large door that opens and has a pull out drawer below that is a freezer
25 is too warm for freezer section
are coils snowed over complete or just on top 2 passes
if snowed solid defrost problem
if only snow on top fc fan is not running or system low on charge low side leak
unrelated if your mod is correct there is a hinge recall that should have been replaced
May 30, 2017 | Viking Professional VCBB363SS Stainless...
Can't find the model number - our fridge is old; about 20 yrs. Freezer door won't seal so cold air leaks, ice forms, water drips at the door handle. My husband tried beefing up the magnets, but that...
model on that vintage very well might be behind the bottom lover vents. remove vent screws and kick plate vent. look for a piece of paper in a taped on envelope. also sometimes on a sticker on the back of the unit.
hope this helps you.
Jan 24, 2018 | KitchenAid KTRS19KKSS Top Freezer...
Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
Apr 23, 2010 | Refrigerators
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
Mar 06, 2009 | Whirlpool ET1FTTXK Top Freezer...
Handyman in NJ
Oct 01, 2008 | Frigidaire FRT18B4A Top Freezer...
Refrigerators Logo
16 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
