Question about Dryers
How to relplace heater element in fisher and paykel ad39 dryer
Do I have to take out drum to get at back of the heater element?
SOURCE: help with a noisy Fisher & Paykel dryer
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
Posted on Dec 22, 2007
  • 1462 Answers
SOURCE: Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Posted on Nov 14, 2008
dragonsthatk
  • 547 Answers
SOURCE: MAYTAG DRYER DE-306 REPLACING HEATER ELEMENT
the elament is in center of drum take off back of drum
Posted on Feb 18, 2009
graemevm
  • 519 Answers
SOURCE: fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Posted on Jun 18, 2009
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
Fisher and Paykel ED56 dryer won't run.
Glad to got it taken care of. Next time be a little more careful, I usually recommend using a leaf blower.
May 10, 2015 | Fisher and Paykel Dryers
No heat in dryer
Turn on your dryer and tests your heater element.. see you have 240v going to it... if you do and no
heat you have a bad heater element
Mar 25, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Heating element will not shut off after drying. Top of machine is warm/hot all the time.
Pull the plug out of the outlet , wait 30 minutes and replug it. This may fix it. If it doesn't it sounds like the relay that operates the heater is faulty. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will show you where the relay is located, check the posts regarding heaters, it should help.
Jul 01, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer won't heat at any setting.
Check for tripped twin breakers in the house electrical panel--push off, then on. If no help, then likely burned out heater element or open thermostat that controls the heater. These parts are usually behind the main drum and require removal of the drum to access. Hope this helps!
Jun 27, 2010 | Fisher and Paykel DE06 Electric Dryer
Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
AD55 Dryer makes a dual clunk like it is out of round.
Run the dryer and look through the front door and watch for if the drum is running out of round at the back. The AD55 only has one bearing and this is at the rear of the drum, the front of the drum is supported by 6 plastic tabs that it glides over. These tabs are reversible if they become worn and a drum bearing assembly kit is available from Fisher & Paykel. For a detailed drawing of the dryer contact your Fisher & Paykel service center and they will email you a copy.
Mar 02, 2010 | Fisher and Paykel Dryers
Fisher and paykel 460 dryer not producing any heat ? heating element ok
one of the 2 thermostats have failed, most have a reset button you can push pin into this will test if it is faulty, they are normally located near the heater element, you might also be able to tell with the reset one being slightly scorched45d764d.jpg
Aug 19, 2009 | Fisher and Paykel Dryers
Fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Best wishes,
Graemevm
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
