Question about Hitachi 60SDX88B 60" Rear Projection Television
No picture or sound
TV was on, changed the channel, picture went out,changed the chanel back and the sound went out. Light comes on when power button pushed, sounds like it's on but have nothing on screen.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
I know this set pretty well, in fact I think I have the service manual on disc---have about 200 of these sets on disc. I can make some suggestions if you have some mechanical skill etc, I never know how much a person has who posts a question here.
I suspect this set might have a common problem---I would have to dig the disc out to be sure----some of these have a small blue High voltage cap that pops (you might not hear it go) and with it goes a pico fuse---its 2 amp and it will among some other things kill the set except for the power light.
If you have a working remote also call up Menu to see if on screen menu is working, if it shows the cap mentioned is good.
Also you can try one of the rear inputs with a vcr or DVD to see if picture that way.
Let me know if I can help.
SD TECH
Posted on Dec 06, 2012
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
  • 927 Answers
Good Day, you all;
The front panel light on Hitachi TV does not really tell you much. To see what the TV is doing or better said NOT doing is remove back from the set.
If you are not a technical type person, it would be better to consult an authorized service center, but if you are perform this; 1. Remove back
2. Observe led and notice which once light, there are as many as 9 LED's.
Now that will tell you what area of the TV's circuits are to be concerned about.
Let me know, Good Luck, big IRISH.
Posted on Aug 06, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: no picture or sound
You have a problem with the high voltage section that drive the projectors. Look in the back to see if the three projectors are lit. Then we go from there.
Posted on Jun 30, 2009
  • 2187 Answers
SOURCE: Hitachi 43FDX20B, watching tv, screen went blank,
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Posted on Jul 24, 2009
SOURCE: 51" no picture, no sound, boutht 12/2006
j ai le probleme sur la mienne , cest qu oi la solution
Posted on Jan 16, 2010
My Goodman tv..When I change chanels I get sound but no picture. If I Turn it off and change chanel then turn tv back on I then get picture,Please can you help me withmy problem.Pat
Ocassionally. digital TV did not load correctly, and must reboot and load firmwware to get the digital signals for the TV. Changing channel is not necessary for firmware to load correctly. But powerline glitches might cause a problem..
Nov 17, 2010 | Televison & Video
No sound on analog channels
I came across this problem yesterday. Digital channels sound... Analog no sound. press the tv button on your remote to change it from DTV/TV
go to any channel you want. press the menu button then go along to Sound setup. In there you will see quite a bit. I went down to an option in there.. it was sound input or something similar. this was set to BG I changed this to 'I' and the sound came straight back on. Hope this helps you out.
Little Dish Fitter
Sep 02, 2009 | LG DR787T DVD Recorder
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Insignia Ns LCD-19 Turns on but no sound or picture
Insignia is Best Buy's store brand which is an LG tv. The power supply board needs to be tested to see if all the voltages it produces are present. If they are, then look at replacing the main board.
TV Parts Universal TV Stands DLP Chips ShopJimmy will have the parts you need.
Mar 20, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Hitachi 60SDX88B 60" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
