Question about iLO 3200 32 in. LCD Television
Wont turn on
When i press power i can hear a noise coming from the power board
    Top Expert:
  • iLO Master
  • 14,553 Answers
I presume you looked for bad caps (filter caps on the power board) and found none?
I would have a good look at that board and if able check for burnt or clearly damaged parts like the caps--failing that unless you want to gamble and but that board and put it in find a expert to look it over for you.
what to look for if a filter cap is bad:
Posted on Dec 06, 2012
My samsung flat screen makes loud noise and wont turn on
sounds like a power supply board problem. Be careful. I would up plug it from the wall socket.. the sound u hear MIGHT be something on the circuit board heating up and about to POP. The power supply boards are not hard to replace. just make sure it is unplugged and be careful they can carry a charge even unplugged. Caps etc can Zap u.. as I tell every one , take picture of the insides of TV and the power supply board and a close up of all the numbers that is on the power supply. order the exact same part.. do not remove the bad board till u have the new one ready to go in.. good idea is use a grounding strap. the only cost a couple dollars or so.
Jan 07, 2015 | Samsung Televison & Video
My JVC TV wont turn on, the blue LD at the front of the TV comes on, when i press the power button the blue LED goes off and i hear a click on the TV but it wont turn on.
Look at the power supply board, look for capacitors ( look like black or brown cans) that have their silver tops bulging. There is a cross on the top designed to open in a failure so the capacitor doesn't pop. Even if the top is still closed, the slightest bulge indicates a failure. Unsolder all bulging capacitors and replace with same spec. For instance, in a bad Samsung there are 4 1000mf 25v 105C rated caps that always go bad, same symptoms. The caps are about $3-4/pc in USA.
Dec 04, 2014 | JVC LT-40X667 40 in. LCD Television
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Wont come on green light comes on three times
Check hori output Transistor if it is shorted set will not come on Part # NTE2324 if it is ok CK second ribbon connector on the deflection board going to board on right. make sure it is in good if it isnt set will make noise and not come on,
Dec 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Mother board problem
The noise must be coming from the power supply. The only thing running before you press the power on button is the PSU.
Unplug the power cord on the PSU. Check the back of the PSU for a red slide switch. Make sure it is set for 115v. Than disconnect the main power from the motherboard. Plud in the power cord, (still hear the high pitch noise?). Swap out your power supply.
Mike
Apr 09, 2008 | ECS RS400-A (V1.0) Motherboard
Power on problems
Having to press the power button multiple times before the set comes on is usually caused by low standby voltages in the power supply or bad connections on the printed circuit board. The "D" board is not your problem. Most likely there is bad capacitor in the 9 volt standby supply.
Nov 14, 2007 | Televison & Video
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
iLO 3200 32 in. LCD Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
