Question about Kitchen Ranges
How to agust polit light on propane stove
Can't find the agustment screw on stove
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Dec 06, 2012
How to agust tappets on a 250 pre cross flow ford 6
If you have hydraulic lifters(tappets) then you turn the adjusting screw 1/4 turn past the point where there is no noise from the rocker arm. If you have solid lifters, then you'll have to get the cold clearance spec for that engine and adjust accordingly.
Dec 13, 2014 | Ford Cars & Trucks
Wont run on idle speed stihl o48av model ok on high speed
the card mite needs to be agusted or idle screw a gusted or carb kit put in it
Jan 22, 2014 | Stihl Garden
How to
U want a manual to follow really pal also ur vid is of the water pump cant see carb but basically replace everything as u found it n ull b fine
Jun 13, 2013 | Toys
Can't find the screw to agust pilot light on stove
What is the model number of your unit?
Dec 06, 2012 | Kitchen Ranges
How to agust clutch on petrol club cart
Don't know much about that brand but most has a clutch Rod or cable that you can adjust out more, Just follow from peddle. Sorry not much more help good luck with it.
Dec 05, 2011 | Cars & Trucks
My 2002 1500 Drifter has been having difficulty starting. It lurkes forward and dies, and wouldnt start last night after this happen. I let it cool down a little and finally got it home. ThIs morning it...
There are only a few things that come to mind right away. If you are: making sure that green (nutral light) is on, and that your clutch leaver is all the way in before starting... then the reason the clutch is NOT fully disengaged is possibly one of these:
(1) If your clutch is opperated by cable, it may need to be tightened.
(2) If it's a hydralic clutch, either the fluid in the resevoir is low, cable needs agusted at the top or at the tranny, or the fluid is getting past the seal in the clutch master cylinder and is in need of a rebuild kit.
(3) The clutch discs are warn to the point where the clutch simply cannot be completely dissengaged any more (this is most noticed at start-up) because once the bike is warmed up it is not as likely to die at a stop light just because the clutch is catching a bit.
Most likely you need to put a kit in your clutch cylinder if the agustments don't work out. Hope I didn't miss anything... hope this is of some help :)
Jul 23, 2011 | 2002 kawasaki VN 1500 Vulcan Drifter
Tail lights stay on also head lights also no dash lights have replaced the headlight switch and the ignition switch now is it the bcm or something else?
not trying to cast any problems but normally you can agust the brightness of the dash light..try turning it up..other than that...there is a fuse box under or in the dash board...make shore the fuse isnt blown.
Jul 20, 2010 | 1999 Plymouth Voyager
Toshiba 43a10
This problem could be the vertical circuit falure, the sweep circuit falure or the video circuit has a fault. Depending on the age of the set will determine on how much you would spend to have this set repaired. Call out an authorized Toshiba servicer, as they would be able to give you a better estimate as they already or should already have the service manual and parts. Good Luck
Aug 07, 2006 | Toshiba 43A10 43" Rear Projection...
Toshiba 27A30 that blows Fuse
Jeff, If your not a technician please dont mess with the set as you can get seriuoly hurt by experimenting. And replacing a fuse that is black is only going to blow again and possibly cause more problems and damage the set more then it already is. Your problem is a shorted B+ rectifier or a capacitor or voltage regulator IC. If you don,t know what this is, or you don't know how to solder, as well as unsolder, Please seek out a pro to assit you with this repair. Good Luck
Aug 06, 2006 | Toshiba 27A30 27" TV
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
