Question about Philips Magnavox 15MF400T 15 in. LCD Television
Magnavox 15MF605T/17B how to remove the front panel to replace speakers?
I need to replace one of the speakers, I removed the four screws in the back; however, I cannot remove the front panel to access the speakers compartment. What am I doing wrong?
    Top Expert:
  • Philips Master
  • 14,553 Answers
I presume the back cover does not really open from the back or if it does you cannot see the speakers from the rear?
which if you cannot see them with rear cover removed leaves two possible paths, the entire panel unit with the screen has to be removed and they are under it OR the entire front may be snapped together and has to be pryed out (if you see a seam or crack like area running around the side up front get a thin metal putty knife and try to open it, seen a lot of computer LCD monitors where they come apart from the front--and are snapped together much like some of our plastic remotes--have to go in from the front and not the rear.
Do some careful looking to see what you have.
Posted on Dec 06, 2012
  • 4 Answers
SOURCE: Problem with Magnavox 15MF605T/17B
Hi SgtHoagie and anyone else:
I ran across this problem too, at 1:30 this morning. At that time I had to get out of bed and try to figure out what the hell happened. It seems that my flat panel TV somehow got switched over to the computer monitor mode. When this happens, the light will turn an amber color. On the bottom of your flat panel you'll see some very small buttons, marked "MENU," "CH" "VOL" and "SOURCE." You'll want to click on the "Source" button and that will switch your flat panel back to the TV mode. Your flat panel TV can also be also used as computer monitor.
Posted on Feb 15, 2008
SOURCE: Low sound on Magnavox tv 15MF605T/17
I have the same problem. Then I tapped the speaker and it would go on louder, then it started going off and then on, really irritating,
Try turning it off and unpluging it for a few minutes and then on again - it has something to do with the static building up.
It worked for me - Let me know if this works for you.
Posted on Nov 06, 2008
rulds2008
  • 3866 Answers
SOURCE: How to remove the back cover on Magnavox 32MD251D/37
These are snapped on tight so if you take a screw driver and go around the lid gently to snap off the seal you should be great.
Posted on Apr 23, 2009
  • 945 Answers
SOURCE: I'm trying to program a new remote for a Magnavox
002 009 109 118 209 309 402 408 502 508 510 807 914 917
Hope this helps.
Posted on Nov 13, 2009
SOURCE: i have a 15MF605T-17 magnavox hdtv monitor. i
power comes on sound works but screen is black
Posted on Feb 25, 2011
Rear panel for a mitsibishi montero speacker removel
1Lift the rear seat all the way up and towards the front of the vehicle.
  • 2Remove the five Phillips screws holding the scuff plate at the rear opening of the vehicle. Remove the scuff plate.
  • 3Use a panel tool to pry off two screw covers on the edge of the headliner in the cargo area. Remove the Phillips screws located behind each of the covers.
  • 4Pull the carpet away from the edges of the rear-side panel. Remove four Phillips screws located below the carpet at the bottom of the rear-side panel. Remove the two Phillips screws holding the cargo cover hooks located on the rear-side panel.
  • 5Pry around the bottom and back edges of the rear-side panel and pull the panel out far enough to access the speaker.
  • 6Remove four Phillips screws from the edge of the speaker with a Phillips screwdriver. Pull the speaker out of the door and unplug the wiring harness connected to the back.
  • Nov 12, 2011 | 1995 Mitsubishi Montero
    Where do I purchase a power cord for a magnavox 15mf605t/17
    its the same as a computer power cable you can find these all over the place. try ebay
    thanks
    michael
    Mar 25, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
    Lost my ac/dc adapter
    Go to the philips-magnavox-funai web site:
    http://magnavox.fox-international.com/
    Use the 800 number ... tom
    Apr 16, 2010 | AOMNI Corporation Magnavox 15MF605T/17 15...
    How do I replace speakers on a 1994 xj6 ?
    Replacement of Front and Rear Door Speakers
    Required Tools:
    #2 Phillips Screwdriver (magnetic tip is useful)
    9 mm Nut Driver
    8” or 10” Flat Tip Screwdriver
    Small awl or other sharp pointed instrument
    Soldering Iron w/solder or 8 to 10 small wire **** splices
    8 to 10 small machine screws -- #8 x ¾” or equivalent 8 to 10 small machine screw nuts & flat washers to match
    Thread locking compound “Loctite” (optional)
    6” wooden dowel of ½” diameter to be used as a drift
    Small mallet or hammer
    1) Whenever you are attempting to a remove door panel to gain access to the speaker, or any other electrical component, absolutely disconnect the negative battery cable. Battery power is supplied to each door window motor and it’s always prudent to de-energize these circuits before you attempt any panel work.
    2) XJ40 door inner panels (front or rear) are comprised of an upper and lower section, which interface to provide complete inner door coverage. Neither panel is difficult to remove nor are any specialized tools required.
    3) Remove the Upper Inner Door Panels as follows:
    It’s a good idea to store all the removed parts and screws in the adjacent foot well for safekeeping and easy access when you are putting everything back together.
    a) Using a small awl (or equivalent), remove the small “square” plastic cover for the inner door lock release mechanism (upper right side when facing inner side of door). It pivots towards the front of the car.
    b) Using the #2 Phillips screwdriver, remove the inner door lock release mechanism plastic / chrome escutcheon. It’s held in place by a single machine screw. Pull out on the door lock release mechanism and the escutcheon is easily removed.
    c) Using both hands, pull out on the wood veneer panel at the inner door lock release mechanism to provide clearance and slide the panel towards the front of the car. The panel is secured on the left side by slip-in clips and they release easily.
    d) Using the #2 Phillips screwdriver, remove the two sheet metal screws on the left side. For the front doors only, lift the bottom of the rubber ventilation boot at the front edge of the door and remove the sheet metal screw. Additionally, for the front door only, use the large flat screwdriver as a lever to ease out the single “fir tree” type press-fit connector. Neither of the rear doors contains these two additional fasteners.
    e) Using both hands, lift the upper inner door panel until it releases from the metal ridge along the window line. It doesn’t take much effort to remove the upper panel as it slides off vertically. Store it on the seats for safekeeping.
    4) Remove the Lower Inner Door Panels as follows:
    a) Using the #2 Phillips screwdriver, remove the sheet metal screw located at the upper edge of the lower panel.
    b) Using a ½”small wooden dowel or equivalent drift, place it under the lower edge of the door handle screw access cover. Lightly tap each end of the access cover using the dowel and mallet in an upward direction to release the access cover. These covers can be tight if they have never been removed in the past, but they will release.
    c) Using the #2 Phillips screwdriver, remove the sheet metal screw located in the middle of the door handle.
    d) Using a small awl or equivalent, remove the bottom door light lens by releasing it from its locator at the rear and sliding it outwards from the door.
    e) Using the #2 Phillips screwdriver, remove the lower panel securing sheet metal screw located in the middle of the bottom door light assembly. All sheet metal screw fasteners for the lower panel are now removed.
    f) Using both hands (and the large flat screwdriver, if needed), carefully pull off the lower inner door panel by release the series of fir-tree type press-fit connectors along the sides and lower perimeter. Once the panel is removed, it can be laid horizontally on the seat as there is sufficient length of wire bundle to allow this movement. It is not necessary to disconnect the wiring harness, but if desired, the connectors can be released so that the panel can be moved to another more worker friendly location.
    5) Remove Door Mounted Speaker as follows:
    a) Disconnect the speaker positive and negative conductors by releasing the electrical connector.
    b) Using the 9mm Nutdriver, remove the speed clip nut from each of the four (4) speaker fastener studs. Press the nutdriver down firmly to engage the speed nut … do NOT cut away any foam material as it is not necessary.
    c) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the left (driver side) or right (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
    d) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately above the speaker. It is located just below the upper sheet metal screw securing tab on the lower panel … the screw was previously removed in Step 4a.
    e) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower right (driver side) or lower left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
    f) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower far right (driver side) or lower far left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
    g) Steps 5c, d, e and f will release the speaker / window lift pushbutton panel from the lower door inner panel. Removal of the sheet metal screws will allow the speaker panel to be pulled away from the lower panel by 3” to 4” to facilitate access for speaker removal.
    h) With the speaker / window lift pushbutton panel eased back for working clearance, grasp the speaker with one hand while pressing the four (4) speaker studs downward through the foam supporting material. After the studs are clear from the foam material, the speaker can be removed from the panel.
    6) Install New Door Mounted Speaker as follows:
    Typically, base XJ40 models use 3.5” door speakers while the VDPs will use 4” door speakers. Though I believe it is possible to mount either type in either model.
    a) Using the wiring supplied with the new speakers and insulated solderless **** splices, transfer the old speaker wiring electrical connector to the new speaker. Another alternate method is to simply solder the old speaker wires with connector to the new speaker terminals. This is a superior method for electrical continuity and strength of joint … although it does require some soldering skills.
    b) Install the new 3.5” speaker by easing back the speaker panel and sliding in the new speaker. Normally, the 3.5” models will mount with only two fasteners.
    c) Using two of the small machine screws with flat washers, place these fasteners through the speaker mounting lugs and press them up through the existing holes in the foam supporting material. Secure the screws with flat washers and matching nuts from the back side of the inner door panel. The use of thread locking compound (Loctite) is a nice touch to prevent loosening due to vibration.
    d) Re-install the sheet metal screws removed in Steps 5c, d, e and f. This will re-mount the speaker panel. Don’t forget to re-connect the speaker wire connector at the door panel.
    7) Re-installation of the inner door lower and upper panels is literally a reverse of the removal procedure. No hidden tricks.
    8) Perform Steps 3 through 6 for the other doors and the job is complete.
    9) Remove Rear Footwell Mounted Speaker as follows:
    This sequence is good for both 4” and 5.25” footwell mounted woofers.
    a) Using a small flat screwdriver as a lever, carefully ease off the grill.
    b) Using a #2 Phillips screwdriver, remove the four (4) sheet metal mounting screws.
    c) Ease out the old speaker and release the electrical connector for the speaker wires.
    d) Transfer the old speaker wires and electrical connector to the new speaker using solderless **** splices or by soldering the old leads to the new speaker terminals.
    e) Re-connect the speaker wires to the harness by joining the electrical connector.
    f) Mount the new speaker and re-attach the necessary sheet metal screws.
    g) Press the speaker grill into place.
    h) Repeat Steps 9a though 9g for the other footwell speaker.
    Mar 10, 2010 | 1994 Jaguar XJ6
    Describe how to replace bulb for magnavox hdtv #50ml6200d37
    easy. pop off the front cover.. Start at the right edge. The front part that covers the speakers comes off as a complete cover. Then there is a square panel that must be removed on the left side front about three screws. once the panel is off there is three thumb screws .. loosen them.. they do not come out. then when they are loose pull on the panel handle and out comes the bulb unit. then follow the install instructions of the new bulb. Do not touch the bulb with your hands... It goes back the same way .. The exterior panel must be in place for the tv bulb to fire up..
    Oct 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
    I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
    Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
    Radio Speakers, Front Door Removal
    1. Remove the front door trim panel (23942). Refer to Section 01-05 .
    Trim Panel(s), Door Front
    Removal
    1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
    2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
      Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
    3. Remove the three cover caps and front door trim panel screws.
    1. Remove the one front door trim panel capped screw from the door pull handle.
    2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
    3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
    4. Remove the front door trim panel.
    Door Electrical Connections
    Removal and Installation
    Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
    Removal
    1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
    1. Remove the front door watershield by carefully detaching it from the adhesive.
    1. Remove the four front door radio speaker screws.
    May 20, 2009 | 1997 Mercury Villager
    Need to replace roller's on LG Tromm Gas front load dryer. The back seems to be stamped to the side panels. How do you take apart the dryer to get at the inner workings?
    Unplug power cord. Remove phillips head screws on the bottom side of the "L" bracket on the back side of the dryer's top. Use the flat sides of your hands to sharply push back on the dryer's top, sliding it back about 2 inches and then lifting it off. Remove screw from top corner front corners and pry control locking tabs off from along top edge. (watch for sharp edges) Swing control panel up onto top of dryer. Remove the two screws at the bottom side of the door opening and the four screws along the top of the front panel. Unplug the light, door switch, and also the moisture sensor (by the bottom of the drum) then remove front panel. Remove four screws holding front drum support and lift up on it a bit to remove. Look at how the belt goes around the motor and pulley before removing, then take out drum. You will need to remove the phillips screws from behind dryer to remove the rear drum support assembly, allowing you to get to the nuts on the back rollers. First time job: maybe 2 hours. Second time: maybe a half hour, tops.
    Feb 24, 2009 | LG WM-2277HW Front Load Washer
    Oct 07, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
    Feb 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
    Philips Magnavox 15MF400T 15 in. LCD Television Logo
    85 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
