Question about White Sewing Superlock 1934D Mechanical Sewing Machine
How do I thread the White Superlock serger? - White Sewing Superlock 1934D Mechanical Sewing Machine
  • White Sewing Master
  • 7,365 Answers
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
How many thread do I use to serge the edge of a fleece blanket
Posted on Mar 13, 2014
  • 4 Answers
SOURCE: is there a downloadable instruction manual for White Superlock 2000 ATS serger?
you're in luck, I have the same model and manual, I can copy it and put it to you in a file and email it to you if you want.
Posted on Apr 26, 2008
  • 10 Answers
SOURCE: threading my whites superlock 2500 serger
You can get sewing machine manuals online at sewingmanuals.com. I didn't see the superlock 2500 but there were other superlocks. They may thread the same way.
Posted on Jul 31, 2008
  • 323 Answers
SOURCE: White Superlock Serger 1934D
Either adjust your knife to cut wider or tighten both looper threads.
sewman7
Posted on Aug 11, 2008
  • 6 Answers
SOURCE: I lost my instruction manual fro my serger white
I found a free pdf manual for my 20 year old White serger at singerco.com. Hopefully you can find yours too.
Posted on Feb 09, 2010
  • 123 Answers
SOURCE: left needle thread keeps breaking
the tension must be too tight or check to make sure the spool does not have a crack that is catching the thread in the middle of using the serger. When the serger is working and the spool has a crack it catching the thread then you press to go on and it gives a break the needle because the spool is still holding onto the thread
Posted on May 02, 2010
I have a white speedy lock serger model 7340. I completely pulled all threads out and now trying to re-thread new thread. I have tried around 15 times. It will not loop. Threads don't interlock at all
Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
Jan 06, 2017 | Sewing Machines
I need to thread my White Superlock 1924D were can I find on the internet
White sergers (Superlocks) and sewing machines were made by Singer. Singerco.com has many of the manuals available as a free download: http://www.singerco.com/support/instruction-manuals .
However, I've never heard of a White 1924D. Did you give the correct model number? The threading diagrams for the 1934D is in part 1 of that machine's manual start on page 18. The direct link to this manual is here: http://www.singerco.com/uploads/download/982_sl-1934d,2000-a-x.pdf .
Most White Superlock machines have very similar threading directions. I hope this helps.
Jul 02, 2015 | White Sewing Superlock 1934D Mechanical...
White Superlock serger continually breaking needles
First take all the thread out of the machine. Put in new needles and run the machine slowly by hand and see if there is a problem with timing. If the needle hits and bends or breaks... take it in to be timed. If the needle don't hit....
Make sure you are properly threading this thing. Unlike a sewing machine which gives you some leeway, Sergers must be threaded in a certain order. Typically, upper looper, lower looper, right needle left needle. If you break a thread you can't just rethread that thread... you have to start from the beginning.
You might check singerco.com for the manual for this thing. They have most of white's manuals online they are identified by a W before the serger model number.
Oct 04, 2012 | White Sewing Superlock 1934D Mechanical...
Jaguar white 228 serger
go to the website of sewvacdoctor.com & email them about a manual
Mar 05, 2012 | White Sewing Sewing Machines
Left needle thread keeps breaking on my White Superlock 2000 ATS serger
May 02, 2010 | White Sewing Superlock 2000 ATS Mechanical...
I lost my manual and don't know how to thread the White Superlock 834DW electronic serger
Here is another singer threading manual
Should be the same.
www.singerco.com/pdf/14SH654_threading.pdf
Singer (white company) has a really good website.
You really want to reinvest in a manual for your machine, they really are a necessity.
Good Luck
Mar 30, 2009 | Sewing Machines
White Sewing superlock 1934D
I don't know how you rethread after the thread breaks but my wife has had 3 or 4 sergers and has found that if a thread breaks you MUST unthread and start at the beginning and not just try to rethread the one that has broken or you will have trouble.
Aug 27, 2008 | White Sewing Superlock 2000 ATS Mechanical...
sewman7
Aug 09, 2008 | White Sewing Superlock 1934D Mechanical...
Threading my whites superlock 2500 serger
Jul 30, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing Superlock 1934D Mechanical Sewing Machine Logo
898 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
