Honeywell thermostat Model RTH111B My thermostat
Honeywell thermostat Model RTH111B My thermostat is currently set on heat and my fan is always on auto. It seems to get pretty hot in my apartment so yesterday I turned my thermostat down from 68 degrees to 64 degrees. When I got home I checked my thermostat to see if there was any change in temperature and it did not change at all..yesterday it stayed at 75-76 degrees and today it is still at 75 degrees...any suggestions would be great! Thank you!
  • Heating & Co... Master
  • 1,199 Answers
Did you happen to turn the tstat over to cool?
Posted on May 29, 2017
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
What is the thermostat controlling?
Destinova
  • 46 Answers
SOURCE: problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
Posted on May 27, 2008
  • 833 Answers
SOURCE: I have a honeywell mercury
Are you sure it is calling for heat?  Disconnect the stat and see if you still have system operation (Be careful if this is a line voltage unit).  If so, the stat is not bad, there is a problem with the relay or with the wiring to it.  If not, there is probably a short in the anticipator within the stat.  This is a heating coil which helps the unit figure out how much heat 'will' be coming when the contacts close. This cannot be repaired.
If you have a line voltage system, you can still obtain thermostats which run on them.  The better option is to put in a 24v relay system.  You can get advice on how to do that at any home store....about 30-40 dollars and then get one of the new programmable stats.  This will save energy and be more accurate. An energy star unit is a better bet anyway, it will save its cost in about a year.
Posted on Nov 23, 2008
Accurate Joe
  • 61 Answers
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
Posted on Nov 30, 2008
  • 308 Answers
SOURCE: thermostat problem ?
If you start by looking on your gas valve, you should find the correct amperage to set the heat anticipator at. I am not sure if you have a forced hot water system or a steam system, but depending on the case, you may also have a second problem, which is easily addressed. If you have forced hot water, the upstairs baseboard/radiators may be airbound and need to be bleed. If you have steam, you may need to slow down the downstairs valves, and open the upstairs valves to get a balance. Hope this helps
Posted on Jul 09, 2009
meBNme
  • 334 Answers
SOURCE: Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Posted on Aug 31, 2009
Just moved into an apartment with a Honeywell RTH111B. When I got here it was 75, five hours later it's still 75 even though I set it for 68. Any hope I can get to a comfortable (for me) temp?
Temp depends upon ur action of opening and closing door frequently and also depends on your system whether filters are cleaned or not. Plz check.
Sep 02, 2015 | Honeywell Heating & Cooling
When the selector switch is set to off and the fan switch is set to fan on ,the A/C unit runs also. I have checked the wiring and it appears ok. Any ideas.
Its probably feeding backwards through the non-adjustable cooling anticipator to energize the cooling circuit because the subbase is internally wired to automatically energize the fan circuit on a call for cooling. It shouldn't happen though.
Jul 24, 2015 | Honeywell RTH111B Digital H/C Thermostat
Installing a Honeywell RTH111B. The lines coming in are not color-coded.
W- Heat
Y- Cooling
G- Fan
R- Power/24v
B- Common/Ground
Line looks like your power, but beware that usually when it is labeled "line", its a 120v thermostat. I don't believe that this model thermostat is 120v. Just something to check. Hope this helps and good luck.
Jan 16, 2012 | Honeywell Heating & Cooling
I wont to replace my old robert shaw 9400 thermostat with a new honeywell rth111b thermostat but dont known the color wireing diagram
Hello, if this is a standard straghtcool/heat unit then Red- R terminal or Rh white- W terminal Yellow - Y terminal Green- G terminal Blue- Common terminal ( not always used) but ifyou do have a blue wire it will connect to this terminal.
Nov 19, 2011 | Heating & Cooling
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
COOL
OFF
HEAT
Aug 31, 2009 | Heating & Cooling
I have a honeywell III chronotherm thermostat /It won't turn on the heat or the air conditioning when turned to those settings, but it sometimes will when turned to "auto". The batteries seem fine, no...
it sounds like it is time to repalce the stat, auto is set to allow the fan to run only when the heat or a/c is on, the switch for heat and cool will select either, and the temperature lever should allow contact for the bulbs to bring on the desired component. there are no replaceable parts on a thermostat, or I would try to walk you through replaceing them. good luck.. I prefer the honeywell vision pro or the white rodgers 9500 series stats
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
